RIDERS CUB DISCUSSION
- cornmek1
Re: RIDERS CUB DISCUSSION
Just checked my old emails - definately ordered a spare set of front brakes.. so I'll go to my box & have a look.
What do you need ? Photos , measurements ?
regards
Kev
regards
Kev
- gtd65
- gtd65
Did you leave the kick-stand down?bikerbaker wrote: ↑Thu Jul 19, 2018 11:57 amStill waiting for Josh to buy the tyre so I can investigate.
The failure to start was all my own fault.
I need to take the brake pedal off of the Kayak as it took on a new shape on a Derbyshire byway, after hitting a rock.
I keep meaning to disconnect mine but never seem to get round to it!
Mine is a bit of a bar steward, if left for several weeks or months, so you have my full sympathies!
I did. I do it quite often on the Kayak too. Excuses are that it was very hot so brain fade. Also had been using the C90 which is E/S. I usually twig after a while but spent about half an hour and gave up.
I also get confused from time to time by the indicator switch being on the left.
- cornmek1
Front Brake Shoes Piccy - measurements ( 12cm across ) - parts, book
https://drive.google.com/open?id=1oh5RP ... UYP3V8d8E9
Only marks are that T(f) ?? logo and the CH in two concentric circles..
Might even have a spare set amongst a load of stuff an ex-Riders rider gave me.. pm if reqd
regards
Kevin
regards
Kevin
- gtd65
Cheers for that Kev, noticed the image of the parts list was for the rear brake?cornmek1 wrote: ↑Mon Jul 23, 2018 8:19 amFront Brake Shoes Piccy - measurements ( 12cm across ) - parts, book
regards
Kevin
I'm wondering if I have something similar in my paperwork, then again, sitting here in the desert in the UAE it's not readily to hand
- cornmek1
My mistake - I'll get the front brake in that folder tonight
regards
kevin
regards
kevin
- gtd65
Need a cheap battery?
https://cpc.farnell.com/leoch/ytx4l-bs/ ... gJYg_D_BwE
Just ordered one @ £11.57 delivered.
Will be interested to hear how you get on with that, I need to get a battery for the Stream which is the same size. This is 50cc 2 stroke e/s only, no kickstart!gtd65 wrote: ↑Fri Aug 24, 2018 10:42 amNeed a cheap battery?
Hope to be fettling the Riders soon, tyre arriving today and need to sort out a rack that will fit with the grab rail around the dualseat.
- gtd65
I'd imagine most of the batteries are the same units but with a varying label on them.
I'll try recharging my original one with an old school charger this weekend. I've only got a smart charger which won't do anything...
Hopefully get the new one next week
