New member!
dorset tone
Rides:: bmw r80 outfit bmw r1200gs and honda c90
New member!
Post by dorset tone » Sat Mar 31, 2018 8:33 pm
Hi just rejoined after a few years, my partner hasn't ridden for 18 years so thought the c90 was the ideal start back bike (and I wanted another one!)
The one I bought seems fairly sound but the centre stand was a bit corroded so managed to get a replacement
My question is and probably a common one how can I get the shaft out?
Is it one piece right through to the rear brake pedal?
Tried WD40, plus gas, heat no luck
Larger hammer?
Rides:: 12v 1988 e start C90, Gl5oo silverwing ,suzuki GS500F
Re: New member!
Post by wightegi » Sat Mar 31, 2018 8:48 pm
Welcome it will not come out buy a new shaft,cut the old one out.
Not what you wanted to hear but it is the only way ,then grease the new one and oil it often.
Stick a rough location in your details and get to the Isle Of Wight meet in August.
dorset tone
Re: New member!
Post by dorset tone » Tue Apr 03, 2018 11:36 am
Many thanks I thought that might be the answer
Am located in Bridport
PhilB
Rides:: C70zz, C90zz, Tiger 955i
Re: New member!
Post by PhilB » Thu Apr 05, 2018 9:05 am
Welcome!
Hope you see you on the southern weekend!
dorset tone
Re: New member!
Post by dorset tone » Sat Apr 14, 2018 6:24 pm
Well managed to cut the old centre stand off went to fit new one and it is totally different!
Centre pin diameter is way smaller and return spring lug is on the opposite side I guess I have bought the stand for a later model?
Re: New member!
Post by wightegi » Sat Apr 14, 2018 7:04 pm
Ok then Bridport in your details and the year of the bike ,the stands did not change for the C50/70 and 12 volt bike ,I have a C70zz stand on my C90. Wemoto list most years ,I have their page stored in bookmarks for each of my bikes ,it makes it easy to find what parts are available before i look all over Ebay.
Cables are best sourced from Honda pattern ones are rubbish .
jammy james
Member formerly known as james cub
Rides:: 1989 Honda 90 cub (elec start!)1988 honda cub. 2010 Suzuki fl 125 address+
Re: New member!
Post by jammy james » Mon Apr 16, 2018 9:19 pm
Good to see more southern c90's on here, me and a pal are just down the road just outside Bournemouth and are out and about for rides on the cubs and other bikes when we can. We like Portland and surrounding areas...
Who is online
Users browsing this forum: No registered users and 2 guests
