Hi,
Due to being an amputee right leg, I have added a c50 lac swing arm and rear brake set up. I have a problem because the left brake lever doesn't seem to work the rear brake rod. Any ideas would be gratefully received, hoping to get it mot'd for the summer. cheers, Steve
c90 with c50 lac swinging arm
- Rides:: Honda vision 110, honda spacy 250, yamaha gear 50 4t, vespa px200 and sidecar
Re: c90 with c50 lac swinging arm
Take some pictures of the setup, Steve.
Someone on here will work it out.
Hi Steve I have the same set up on my plop racer,c90 bike ,c50 lac swing arm so I might be able to help , pop a picture up like capitano suggests
- steveST100
- steveST100
Photo i saved from the net.
Hi all thank you for your help. Just found a c50 lac rear brake and rod complete. Definitely on the road on it 2018!
