SH300 - heated grips advice
Re: SH300 - heated grips advice
Better not forget to switch them off then.......
Best one I found (it was brought to me to look at); had been fitted very neatly, complete with a relay and fused connection to the battery. The guy tried to wire the live feed from the brake switch - a perfectly good idea. Unfortunately it was connected to the wrong side of the brake switch so they only came on when the brake was used.......
He hadn’t noticed when bobbing around London for 2 years; but then he moved.
- Rides:: None at present
Sorry my mistake........I mean are they big fittings/ small fittings regarding garment sizeCapitano wrote: ↑Fri Nov 24, 2017 12:16 amMine goes straight onto the battery terminals....Wuyang wrote: ↑Thu Nov 23, 2017 11:17 pmCool......any advice regarding the fittings....Capitano wrote: ↑Thu Nov 23, 2017 11:10 pmYou won't regret it. FWIW I have the heat controller but never use it. I wear the waistcoat next to a base layer and plug it straight in.
https://www.keisapparel.co.uk/product/k ... odywarmer/
Sizes up to about 60" chest in 2" increments. They fit pretty much as measured.Wuyang wrote: ↑Fri Nov 24, 2017 11:03 amSorry my mistake........I mean are they big fittings/ small fittings regarding garment sizeCapitano wrote: ↑Fri Nov 24, 2017 12:16 amMine goes straight onto the battery terminals....Wuyang wrote: ↑Thu Nov 23, 2017 11:17 pmCool......any advice regarding the fittings....Capitano wrote: ↑Thu Nov 23, 2017 11:10 pm
- fatboytours
- Rides:: C90T,C70 12v, C125, BMW 1200GSA, Triumph Thruxton R, Blood bike BMW R1250RT
You all need to speak to BCP. He has the SH300 fitted with heated grips and Tucano. Known as the Silver Cross pram in certain circles
- Viper254
- Rides:: Suzukii Address i 2010,Honda 300i 2007
Hi,I’ve got a 2007 sh 300i and I recently fitted Oxford heated grips,they are simple to fit,the wires for feed to the grips and the controller travel “uphill” then through the small inspection holes (for checking the brake fluid levels) then making a connection to the cig lighter feed wire,make sure you get the polarity right,the panel to take off only require 2screws removing and the whole job takes about 40 mins but now I know how to do the job it would take half that time!
The grips can’t be left on,they have a sensor in the electrical system and if no electrical activity is detected they automatically switch off.
Sorry I can’t remember which model of grips I fitted and I am away at the moment for a few days so I can’t look it up but they have a size chart for the different model of grips on eBay,mine are a perfect fit and work well.
I fitted Oxford grips to my 250 cbf and they was very easy to fit and worked well,
They are just under £50 on eBay,Geoff from Preston has fitted Oxford grips to his 125 sh,
Cheers Tom
Cheers Tom
- Rides:: PCX 125, Vision 110
which panel do you take off Tom???tom robinson wrote: ↑Sun Dec 24, 2017 10:48 pmHi,I’ve got a 2007 sh 300i and I recently fitted Oxford heated grips,they are simple to fit,the wires for feed to the grips and the controller travel “uphill” then through the small inspection holes (for checking the brake fluid levels) then making a connection to the cig lighter feed wire,make sure you get the polarity right,the panel to take off only require 2screws removing and the whole job takes about 40 mins but now I know how to do the job it would take half that time!
Cheers Tom
- Rides:: Anf125i
These rubber boots, which are worn over your normal motorcycle boots, and still allow me to change gears on my Innova, work wonders for keeping my feet, and as a result thereof, my body warmer.
They are made of high-quality rubber and completely waterproof.
I have heated grips, and would buy handlebar muffs if I really needed to go anywhere on the Innova.
I have a DeWalt heated jacket as well
https://www.bundeswehr-und-mehr.de/a-1861/
- Hightechpete
- Rides:: Streamline Innova,Honda Shadow,Jialing 70,C100,Honda 400,Helix
Got a pair of heated gloves for Christmas, better and cheaper than my heated grips. Can't say how long they'll last, but nice and toasty.
link below :-
https://www.amazon.co.uk/PsmGoods%C2%AE ... JJNRJV8D3R
link below :-
