Can someone explain the Ratchet Strap front end mod?
- Rides:: ccm, honda, Aprilia
Seen this on one or two bikes.
I can only see that it adds preload to the front or virtually removes the front suspension.
Is that a fair summary?
Does it improve handling?
Re: Can someone explain the Ratchet Strap front end mod?
It just stiffens the front end more and some swear by it , I've personally not tried it but it's the cheapest one to try first
- Rides:: HONDA SUZUKI
never seen or heard about do you have any pictures please
- Alan CF
I had a picture somewhere, It goes round the front link arms and over the mud guard or higher, then pulled tight.
As Alan says, around front link arm,up forks through forks where plastic bungs are then back down around other link arm.
More to do with keeping the front end under control during braking I suspect...
- Rides:: TZ Spondon 250
All it is going to do is reduce the front suspension travel, make the front end go solid under braking.
That means no front tyre grip and a quick visit to Mr Tarmac. I know it probably tops out at times under extreme braking anyway, the rear brake is the most effective on the bike and you can modulate the front lift using the rear brake.
What the front needs is damping, lots of bikes on the grid with good engineered solutions go take a look and copy!
Thanks everyone.
It's as I expected I think and agree with Drew. That's why I asked
Ive seen the damping rods connecting up the front fork and if you can't beat them join them!
There's plenty of time until next year to fettle something, guess it's just a matter of obtaining the right damper and then fabricating a fitting solution.
See you next year and best of luck to those at Anglesey, it's a great track!
Dave
Here's a pic (hopefully) of the strap mod, but judging by the tab on the fork a damper may be in place on race day.
https://photos.app.goo.gl/eIwfw7QiQ1qzHMZV2
Dave
