Got one of these the other day, Fits both bikes,
I thought the 10mm part might stick through and let the piston give it a clout, But its no where near,
Bargain at £5.99 free post.
http://www.ebay.co.uk/itm/Draper-10mm-1 ... 2241389069?
compression tester adapter C90/CG
- Alan CF
- ally
- Rides:: forza 300 v90, v75a, c90-g, fj1200, CG125ES, cb250, ybr250
- Rides:: C90 CBR600 PE175
Re: compression tester adapter C90/CG
Does the extra protrusion into the combustion chamber make the compression reading higher as its reducing the compression area and therefore increasing the compression ratio
- Alan CF
Good Question,loadedtoad wrote: ↑Sat Jul 01, 2017 10:24 pmDoes the extra protrusion into the combustion chamber make the compression reading higher as its reducing the compression area and therefore increasing the compression ratio
When i screwed it into the CG head the extension sat about flush with the threads when screwed in, All i can think of is that the CG spark plugs have a longer reach thread, So they made this shorter and the 10mm extension compensates.
