Wave / Innova FI extra tank capacity
stevew
Rides:: MaxSym 400i (2013) Wave110i (2014)
Post by stevew » Sat Dec 31, 2016 7:35 pm
From the diagrams it looks like it is integral with the tank. Fitted in to a hole in the top of the tank.
A mere £270 for a new one :o
onittino3
Rides:: Honda C90, Honda Cb500x
Post by onittino3 » Sat Dec 31, 2016 7:55 pm
Its a separate part that sits inside the tank and is bolted to the top of the tank, so can be removed, also it doubles as the sender unit for the fuel gauge, it does have a fuel filter that is replaceable on the bottom of the unit, which sits on the bottom of the tank.
I would buy a second hand tank, (currently one on ebay for £15) cut the fuel pump mount off and use that in a custom tank, and keep your tank as is, so can be put back to standard if required the problem is the reach of the pump, although it does look like you could remove the filter and connect a piece of hose to the end of the pump to lengthen its reach then fit the filter to the end of the hose.
It would cost at least £200 for a custom tank, so it all depends on how cheap the bike is, I also think the wave would look great with panniers 8-)
Post by Capitano » Sat Dec 31, 2016 8:58 pm
Carrying a jerry can looks ever more appealing.
Seriously, unless intending to do a Newt and ride non-stop I'd look at converting it to single seat so you can access the fuel filler with luggage attached.
stevew
Post by stevew » Mon Jan 02, 2017 4:13 pm
Been to look at the bike today. Reckon I can get it for 400 quid but it's an 2014 ex delivery Wave with 20k which was owned by the delivery company. So in theory it should at least have been serviced. Plastics are tatty but it rides well and isn't bent !!
Engine sounds well too.
Needs
Two tyres in 1000 miles
Rear brake shoes now
Front calliper stripping now
Chain and sprockets 1000 miles
Pair of mirrors now
Foot peg rubbers now
Should i or shouldn't i ?????
horobags
Rides:: PCX 125, Vision 110
Post by horobags » Mon Jan 02, 2017 4:44 pm
get it.. :P
onittino3
Post by onittino3 » Mon Jan 02, 2017 4:57 pm
I would for £400, engines go for £300, can't really lose :D
stevew
Post by stevew » Mon Jan 02, 2017 5:35 pm
Got it!!
Tis a done deal.......................
This is it;-
https://www.gumtree.com/p/honda-motorbi ... 1207665377
onittino3
Post by onittino3 » Mon Jan 02, 2017 5:50 pm
Well at least its a black one, everyone knows that they are faster than the red ones :D
Post by Capitano » Mon Jan 02, 2017 6:45 pm
Any reason why it had to be photographed on a plastic sheet?
£400 is an excellent price! :D
stevew
Post by stevew » Mon Jan 02, 2017 6:47 pm
Capitano wrote:Any reason why it had to be photographed on a plastic sheet?
In case it was sick !!!
Looked OK underneath to me...........will check again when i go and collect.
Bodywork is pretty tatty though.
