Halogen Headlight Bulbs for 12v C90 Cub.....
Halogen REPLACEMENT 12v Bulbs for C90 Cubs....
NOW back in stock.
http://www.mildhogs.8m.com/shop.html
NOW back in stock.
Re: Halogen Headlight Bulbs for 12v C90 Cub.....
Mine arrived this morning, cheers buddy!
- Rides:: 2007 Honda SH300i
Just placed an order for head lamp bulb and LED rear bulb
I absolutely do not recommend the LED rear bulb, if you value your life. IMHO, they aren't up to the job. That's not just the ones Fuzz sells, I've yet to see ANY one that's 1/3 as bright as a normal bulb. Just my opinion.
- Pjam
- SPAMMER!
- Rides:: C90, C70c, CB500, ANF125, A100 Bitsa
If you see the Suzuki SV 650 there's about 20 of them in two lines in order to bring up the light level!
Yeah, we've done our own tests here, and WE know what we see, dark is very dark where we are, middle of nowhere, and we've put bikes down the lane in the dark, side by side, LED and incandescent, swapped 'em & revved 'em etc.etc. and the LED's are pathetic.
I'm not sure I could convince people by videoing it either, because video cameras pick up light the eye can't see. You can demonstrate this by videoing a TV remote control while pressing the buttons, and you can clearly see the light emitted on the video.
On any of the rideouts you'll easily tell who has LED bulbs they glow about as much as a fag butt.
Unfortunately there are a few ardent fans of LED's IMHO they're misguided, and should get two or more bikes together and do proper tests before advocating them.
HOWEVER, I do accept they use far less power, and accordingly, I have one in a Land Rover tail/stop light IN ADDITION to my rear light, in case the main light should fail.
- Rides:: zzr1100 1993 C90
Fantastic bulb, I realy cant rate them high enough
- Rides:: c90 cub
- digger06
i just bought one, what makes the fuzz ones different ?(if at all?)dickdastardly wrote:http://www.ebay.co.uk/itm/MPF-12v-35-35 ... 3cbcce960b
i must say, my ebay one gives a much improved light, and better pattern
- digger06
i tried a few, i ended up with one that looks like the others, but its white light and was an unbranded cheapo, funnily enough its actually ok,Newtsalad wrote:I absolutely do not recommend the LED rear bulb, if you value your life. IMHO, they aren't up to the job. That's not just the ones Fuzz sells, I've yet to see ANY one that's 1/3 as bright as a normal bulb. Just my opinion.
