Complete 1990 C90E - engine shot
- Rides:: CG125 & ZX9R
finally got round to taking the head and barrel off my C90 after it stopped about 4 miles outside Ryaeder back in 2010
the bore isn`t `that` bad to be honest
however the piston is knackered. The rings are virtually welded to itself and loads of score lines.
It obviously got extremely hot (lack of oil I assume).
Initial thoughts were to get a rebore and a new piston kit and rebuild as there is no play in the bottom end. However......
the gudgeon pin was as tight as hell in the little end but pressed it out with a socket. This is what you can see
it looks a lot worse than it is (!) but even with fine emery don`t know whether you`d ever get it smooth enough to insert a new gudgeon pin in without damage. Looks like its picked up on something.
so I have two choices really - put a Lifan engine in or break it
I`ve already got 2 other bikes so think I`d rather sell it as a whole rather than break it and post
so
Good points :-
Clean example of a 1990 C90E
New exhaust (Bought off Fuzz) that has only covered 85 miles !
Solid bodywork
Complete (obviously partially stripped non working) engine with all ancillaries i.e carb, airbox, switchgear, brakes etc
2 excellent condition chrome wheels
lockable topbox
it was running beautifully before it cruised to a halt about 18 months ago !
Bad points
Tatty seat that has been patched with black gaffer tape
Non runner
Engine that is only fit for spares or repairs
so offers for the whole lot ? obviously you`ll need a van or trailer to collect !
don`t really wanna break it or put on e bay as too many muppets on there
pm me with offers or for more info/photo`s
cheers
Brom
oh I`m located in Tamworth just off junction 10 of the M42
so
Good points :-
Solid bodywork
lockable topbox
Bad points
Non runner
cheers
Brom
Re: Complete 1990 C90E - engine shot
had a fair few pm`s but have only managed to reply to one of em ?
the rest are stuck in me outbox for some reason ?
forgot to mention I`ve owned it for approx 2 1/2 years and V5 present and in my name
Currently SORNED. It was last MOT`d on 3rd July 2010 with 1 advisory - exhaust is leaking but not excessively noisy. A new exhaust gasket solved that.
a week later it expired just outside Ryaeder and hasn`t turned a wheel since so with a fixed/replacement engine this would fly through a new MOT
its been kept garaged ever since I`ve owned it
first £180 cash in my hand gets it and I`ll even throw in a Haynes manual and a Fuzz special heavy duty inner tube !
cheers
if you want to e mail me rather than pm (coz its not working very well) my e mail address is lee dot bromley AT ntlworld dot com (replacing dot with a . and AT with @ and no spaces as don`t want any spam rubbish !)
cheers
Provisionally SOLD pending collection
be sad to see it go
be sad to see it go
- Rides:: c90
hi if you still have your c90 with the shot engine i can pickup tonight providing it has no rot 07517573300
Nah sorry mate its soldukash wrote:hi if you still have your c90 with the shot engine i can pickup tonight providing it has no rot 07517573300
cheers
- dread
is this this one viewtopic.php?f=7&t=7055 or was this that one.
Nopedread wrote:is this this one viewtopic.php?f=7&t=7055 or was this that one.
- dread
wow two on the forum that are both siezed, shame as me mate is after on, and yours is closer to his at kettering.
- Rides:: c90
ok thanks anyway, reallyyyy after a cub, had a couple in the past and wish i never sold em'! ;'(Brommo wrote:
cheers
- krazy kev
- C90Club Clown!
- Rides:: 12V CUB HEINZ
i had a 6 volt 70 engine that had this happen to it. well to be honest it was like it when i brought the bike but i knew about it. i had a good deal though. 10 pints to get the owner drunk and then pay him £15 before he sobers up. the little end was seized solid and i had to cut the conrod to remove the piston. as you can imagine the piston and block was in need of a desperate rebore. this was all caused by the oil strainer being blocked and also minimal oil in the engine. i think there was about 2 egg cupfulls. anyway i had the engine rebored and the crank reconditioned with a new conrod and pin etc and changed the cam chain while i was at it. all the pulleys and bearing were luckily still in perfect order so i saved a bit there. the head was untouched. i just fitted new valve seals and ground in the valves as a precaution. other new parts included new points, condensor and new clutch plates and springs
the engine actually consisted of a full 70 top end on a 50 gearbox.
the bike was back on the road 4 months after purchase in which it was fully gutted and given a good going over
