Various parts
Re: Various parts
Heya,
According to the manual the carb type is PW15HAI, i hope this makes sence to you.
Yh this is a downdraft carb.
Many thanks
Many thanks
- Rides:: C70ZZ, C100 x2, CM90 x2, C50L-AC, St70
Re: Various parts
Not really I've checked out the DD carbs and there are no part numbers like normally found on the SD carbs.
What bike is it for?
quick edit. Some old reference material I have suggests they are marked A B or C on the c100, c50 Carbs. I would guess that the other DD carb is for the early C70.
I'll post a picture. All the carbs are requiring refurb.
Re: Various parts
Pete, I have just found reference to the part number you quoted and my manual shows it as a 6v C90 carb but sidedraught not downdraught?
Re: Various parts
Humm, thats weard, a piccie would help i should be able to reconise it.
Re: Various parts
These are the DD types that I have.
Re: Various parts
Humm, i don't reconise either of those. Maby its a side draft one afterall. I don't spose i could trouble you for a piccie of the sidedraft one that matches the number.
Many thanks
Many thanks
Re: Various parts
This is the only other carb I have that like the early DD types doesn't appear to have any markings of model number.
All the later SD carbs are marked PB35,40,47 etc.
Re: Various parts
I think you may be out of luck from my carb stash. None I have are marked PW15, stick a wanted ad up you never knowPete-18 wrote:Humm, i don't reconise either of those. Maby its a side draft one afterall. I don't spose i could trouble you for a piccie of the sidedraft one that matches the number.
Many thanks
Re: Various parts
Ok will do, thanking you for your trouble.
Pete
Pete
- Boo
Re: Various parts
I think these two are early (pre Z2) C50/C70 (Keihin DP13) left and C100 right (not sure of number) .
This sidedraught one looks like early (pre Z2) C90 to me. (PW15HAI) .
(The Z2/ZZ cable-choke sidedraughts on 50, 70 and 90 are just the same as the 12 volters - Keihin PB series - but with the tap on the opposite side).
Looks like yer man's collecting stopped before '77 models came of age!
