early 6 volt 4 speed bottom end plus 100cc bore kit
mteck-racing
Rides:: 12v roundheadlight 201cc 4valve
Post by mteck-racing » Sun Jul 03, 2011 11:28 pm
i have a early 6 volt bottom end with a custom 4 speed gearbox. same 1st and 4th is same as old 3rd. it is all down gears. it has been made with hoda gears etc
It will need a strip and clean as the engine droped a valve before it was removed. £50
also have a barral bored out to take a +1mm cd175 piston 53mm i think? comes with a new piston and rings barral has been used. it is a direct fit but you may need to mill the piston to drop the C/R. £15
monkey
Rides:: c90, ktm 525
Re: early 6 volt 4 speed bottom end plus 100cc bore kit
Post by monkey » Mon Jul 04, 2011 4:12 pm
Will they fit a 1971 model? if so can you post it and how much will it be? cheers
mteck-racing
Post by mteck-racing » Mon Jul 04, 2011 7:27 pm
hi i am not sure on what years it will fit.
but it is the 6 volt type with the points in the head.
I will post it will be about £15
