C90 1-40 17” wheels for sale £50
- Rides:: Honda C90MG
2x original wheels for sale that have come off a 1987 C90. They are white and in good condition. The front wheel will require a bearing which is easy to fit. I live in York if they can be collected.
- Rides:: C90
Re: C90 1-40 17” wheels for sale £50
Are they genuine Honda wheels?
Do you know if they'll fit a 1996 model?
They've come off a 1987 model 'G'.
They'll only fit a 1996 with the later brake plates. You may also have to change your speedo and brake cable for the front wheel fitment.
This was discussed in a previous post but I imagine Tewy will be in touch.
I imagine you have the later plates fitted as yours is a '96. Unless they've been swapped at some point? (Mix and match).
Cheers Andy.
Cheers Andy.
Hi Tewy and Spesh,
I've just re-read my post and I wrote wrong!
I meant to say earlier plates not later!
THOSE 1987 WHEELS WILL ONLY FIT A 1996 IF YOU FIT THE EARLIER BRAKE PLATES !!
EARLIER BRAKE PLATES NEEDED!!
Also the brake and speedo cables changed.
If those are 1987 wheels, that Tewy has, to fit a C90 'G' then they'll only fit the brake plates on a cub up to approx 1992. The hubs changed from then onwards and you need the corresponding wheels / brake plates to fit.
Apologies again, hope I've got in quick enough before any harm done.
Cheers Andy.
Cheers Andy.
Hi Tewy and Spesh again,
I've just looked at your advert Tewy, the one you had on here for brake plates SOLD.
I can confirm that those are the earlier ones.
So earlier plates needed for those wheels you're selling.
Sorry again for any misinformation / confusion.
Andy.
Andy.
