C90 wheels for sale - withdrawn - new ad placed
- Rides:: Honda C90MG
I am replacing the original wheels that have been painted white (not powder coated) To some people the look would be good but for me I am replacing them for chrome. I could have stripped the paint off but to do it correctly it would have meant removing the hubs. These will be available as soon as I fit the new ones. The rear wheel will come with a chain sprocket, axle, white brake plate. I am trying to get another front wheel brake plate but if not successful I will have to remove the white paint on the old one. This will be a lot easier on this component. Please note I live in York
Reason: withdrawn
Reason: withdrawn
Re: C90 wheels for sale £100
I am open to offers for my 2 wheels which I believe are original but painted white
- Rides:: C90 vespa et4. Cbr600
Hi did these sell? Do you know if they will fit a 94?
'94 was on the Changeover to the later wheels!
They'll definitely fit if included with the brake plates. The rear will go straight in. The front has different brake cable and speedo cable ends. So you may have to change the cables for the earlier ones?
The best way to tell the front brake plate is the speedo fitting. The early ones have a sort of splined nut that screws onto an external thread. The later ones, which I imagine yours is?, pushes in and is secured with a countersunk cross head screw.
So you need to know what Tewy's speedo end is and look at yours. I can't quite see from the photos.
Cheers Andy.
Cheers Andy.
The speedo cable screws in to secure it and the end of the cable has 2 prongs. The wheel size is 1-40 17.
Will accept offers for the wheels
Hi all,
Will accept £50 now for these original C90 1-40 17” wheels.
- Rides:: C90
Hi. Do you ever venture to Halifax or Preston?
This add is not applicable now.
