Honda SuperCub C90G and T spares needed gone
- George
Hello again, I have found some more bits that need gone, prices will be symbolic and negotiable as I need them out of the way. Sold my daily C90s and I don't need these anymore:
Some bits have sold on the facebook page (big mistake in advertising there...) and these are:
- the 6V Rickman fairing
- Lifan stator + rotor
- front rim with spokes (left with a rear rim with spokes)
- both grab handles
What's left is:
- Almost complete seat (hinge assembly is incomplete, one tear on the side)
- 4 x shoe springs OEM new
- Pl, Silencer - 50385-GB4-000 - used part
- Upper handlebar cowl in used condition with one of the fixings damaged but still have the broken piece so could be glued?
- 2 x exhausts, one from a C90T, the other from a C50 Little Cub (50 won't fit a 90 without some mods)
- OEM new side stand bolt + nut + probably pattern spring.
- Pattern complete front wheel C90G type.
- 3 x bolt + nylock nuts + 2 x spacers for the Rickman rear carrier (the one with the side bag support) these fixings go on the indicator stem fixing location.
- 1 x JT front sprocket new 16T
- Some o-rings and 2 x valve stem seals for the C90G type engine (1986 - 1994?) + 2 gudgeon pin clips.
- Both caps for a C90MT E-Start LH engine cover. The one for the crank nut and the other one for the inspection (checking the flywheel markings for the T F marks) These are OEM new.
- 2 x? copper washers for the head stud top nut seal for the oil feed. New OEM
- 2 x valve stem seals for the C90T (1996-2002) New OEM
- 4 x rear shocks in Shuttle Blue.
- 1 x engine guard (this was received as a gift from Diesel Dave, so would accept just the postage fees for it... never fitted it so not sure how it fits).
- 4 x horns. One is pattern and works, not sure about the other 3. 2 of them might need tuning.
- C90G Square spaced indicators Rickman Faring + fixings. No clear screen with this one. Can be bought new. This one was never fitted so as new.
- Rear rim with spokes, cush drive rubbers
- 2 x mirror mounts (original risers) + 2 x LH threaded nuts + the 2 x rubber protectors that come over the nut and risers. These are all new OEM. So everything for the mirrors without the actual mirrors.
- 3 x ring sets, 3 x gudgeon pins, 3 x 2 gudgeon pin clips all new (pattern)
- 1 x ring set Original OEM, a complete lower dirtshield fixing set (long screw + spacer + washer all OEM new but not in their original wrappings), overflow or breather hose for the carb... not sure which one... probably breather. 1 magnetic sump plug and washer, 2 x in line fuel filters, 1 x set of cush drive rubbers, some front forks mounts, etc.
- 1 x brake shoes OEM new
- 1 x throttle cable used.
Feel free to ask anything. I'll take offers for all of these.
Thank you.
George M.
- both grab handles
What's left is:
Thank you.
George M.
- ally
- Rides:: forza 300 v90, v75a, c90-g, fj1200, CG125ES, cb250, ybr250
- Rides:: 1965 Honda C100 1981 Yamaha RD350LC 1995 Suzuki DR350 2000 Honda C90 2017 BMW S1
Re: Honda SuperCub C90G and T spares needed gone
Messaged you
- George
Replied to all.
- George
- George
This is all it's left...:
- 1 x ring set Original OEM oversize
- Rear hub.
- Axle bolt, spacer and nut.
All for £15 posted without the two exhausts. The exhausts will be £10 + postage.
Thank you.
- Rear hub.
Thank you.
- Rides:: honda c90mg honda c90p
Hi George .can I have the odds for £15 posted please , pm sent.
- Rides:: Honda 90
Wondering if you have the following for sale (I have been left really stuck thanks to a powder coater losing these parts)
- front brake arm and cam shaft and Rear brake arm shaft Honda (To fit a 1984 bike)
- Pl, Silencer.
If you have the above please let me know thanks !
- Pl, Silencer.
- George
I will send these to you Valentino. I will be away from today till Sunday. Will be back on Monday and I can post the parcel then if it's alright with you.
Hello Croz,Croz wrote: ↑Tue Oct 16, 2018 11:54 pmWondering if you have the following for sale (I have been left really stuck thanks to a powder coater losing these parts)
- Pl, Silencer.
If Valentino agrees to let go of the PI. Silencer, I could send it to you.
This is how mine looks like:
It comes off of a C90T 2000MY bike. No way near a powder coated finish, but in good usable condition. You might need to paint it. I replaced it with a new genuine Honda part from CMSNL... was the last one in stock and it is discontinued.
The cam shafts and levers are still available with your local Honda Dealer. I will refurb my spare brake plates... I could give you my ones, but it will take some time for me to strip them. Are you in a hurry?
- Rides:: Honda 90
Hi George,
Thanks for the quick reply. I am building a custom cub using a kepspeed frame as my original had literally rusted to nothing. You can imagine what the PI. Silencer looks like lol !.
I don't think I am in a rush still have plenty to do to the bike. I sourced new arms front and back but it came to £29 all in (which is frustrating as mine were fine but the powder coater lost them )
As you can imagine with the custom build my cost is spiralling a bit out of control lol so I am trying to avoid just buying everything new.
I will be phoning at the end of the week to see if they magically appeared (they have been lost for a few weeks now so I have lost hope).
Thanks George !
Thanks George !
