Honda Little Cub C50 12V 2000MY Engine - £50
Posted: Sat Jan 20, 2018 7:23 pm
Used to run when I got it off the bike. Comes with the original carburator and the air box with it's recirculator and all the gizmos that this engine has like some sort of PAIR valve. The engine has the RH case from a Lifan and it's missing a spring from the clutch assembly which I will talk about further below. The little cub has some sort of warning light in the dash for going too fast, the signal comes from the carburator. I will give the buyer the speedo as well which reads 2585.9 km. I think these are genuine kms and the speedo came off the bike together with this engine, so most probably that's the mileage on the engine. Please do bear in mind that the little cub has 14" wheels and the final drive ratio might differ from the 17" wheeled Cubs. Would like collection on this one:
I would like the buyer to collect for this one. Thank you!
George M.
PS: The missing spring is no 6 on the microfiche:
P/N is 22825-046-000 and it's the Spring Cam Plat, common to all C90 engines. Price at local dealer for the spring is £1.39.
George M.
