I have a c70c switch gear that i bought for my cub. I didn’t realise the handle bar diameter was smaller on this switchgear so hopefully it will be use to some one on here.
£30 posted or I will swap for a lac left switch gear with parking brake that will fit a cub
[/img]
C70c rear parking brake / clutch switch gear for sale or for swaps
- Rides:: None
- Norm
- Rides:: Hondas C110, C70C, C50LAC, PF50 Amigo & several Lambrettas and Vespas
Re: C70c rear parking brake / clutch switch gear for sale or for swaps
Just to let you know that the switchgear in your photo is not from a C70C. If it's for the smaller-diameter (round headlight) bars, it's for a C50LAC. If you're after parking brake switchgear for the bigger-diameter (square headlight) bars, you need to look for the part from a C50LAE or C50LAG.
