Bought a new pair of CG shocks, I was recommended to buy them from ( davebike?) somebody on here who supply's them. I had them on the cub for no more than 200 miles, I took them off when the cub was sold,,,,sprayed with wd40 and put back in their packaging.
£37.50 delivered.
Wuyang
Cg125 shocks off Davebike ( think that's his name) £37.50
- Rides:: None at present
Re: Cg125 shocks off Davebike ( think that's his name) £37.50
If they`re in good order, I`ll relieve you of them if they`re still available. I take it that they will fit any Cub? Mine is a 1990.
If you let me know your email I can "gift" you the price (unless you want payment some other way?) & let you know my address.
Cheers, Patrick.
Cheers, Patrick.
Hi Patrick, I believe they fit any square headlight model. They are basically as new with wd40 sprayed on them. My wife says the address is janesstore@yahoo.co.ukHarps18TV wrote: ↑Wed Jun 14, 2017 8:36 amIf they`re in good order, I`ll relieve you of them if they`re still available. I take it that they will fit any Cub? Mine is a 1990.
Cheers, Patrick.
Will update post when there on the way.
Wuyang
Hi Wuyang, the deed is done, with address, thank you.
Thanks, the shocks arrived today just as you described them ( Monday ) & are now on the bike - just needed a packing washer on the N/S bottom to make sure the body of the shock cleared the frame.
Thanks very much Wuyang.
