Frame, engine and wheels £10-£150?
scoops
Rides:: C90
Post by scoops » Sat Jan 14, 2017 6:55 pm
Bought this bike as a project but don't really have the time so thinking of selling but not really sure what its worth.
Frame has the usual rust on back end which has had some rough patches welding on, apart from that in quite good condition.
Engine turns over and has decent compression, the gear shaft appears slightly bent and has cracked the outer casing, its not the main casing just outer so easy to change and replace gear shaft.
No idea if the wheels are worth anything??
Open to sensible offers.
loadedtoad
Rides:: C90 CBR600 PE175
Re: Frame, engine and wheels £10-£150?
Post by loadedtoad » Sat Jan 14, 2017 9:48 pm
Has it got a V5 and where abouts in UK(i assume) are you ?.
£10-£150 is a bit vague it's always best to put the price you want and haggle by PM with those interested.
Is everything in the photos ?.
scoops
Rides:: C90
Post by scoops » Sun Jan 15, 2017 12:37 am
No V5 with the bike so will have to be applied for, the frame is just the frame not forks or tank, i'm thinking around £120.
Im southeast near Tunbridge Wells.
bora2016
Rides:: Vw bora sport, 2012 yam xmax r and Honda c50
Post by bora2016 » Wed Feb 22, 2017 11:06 am
Engine price and cc please
steveST100
Post by steveST100 » Wed Feb 22, 2017 1:21 pm
bora2016 wrote:Engine price and cc please
Engine is a 6v c90 and wont fit your frame.
bora2016
Post by bora2016 » Wed Feb 22, 2017 1:39 pm
Why wont it fit/. any thing is possible :)
bora2016
Post by bora2016 » Wed Feb 22, 2017 1:42 pm
scoops one sold for £25 on here engine that is
steveST100
Post by steveST100 » Wed Feb 22, 2017 2:37 pm
bora2016 wrote:Why wont it fit/. any thing is possible :)
Wrong engine mounts.I know they can be made to fit but to me the 6v c90 is just a door stop.
bora2016
Post by bora2016 » Wed Feb 22, 2017 4:08 pm
Even for parts to fit in my 50 case? sorry I'm still learning
steveST100
Post by steveST100 » Wed Feb 22, 2017 4:16 pm
bora2016 wrote:Even for parts to fit in my 50 case? sorry I'm still learning
Only bit you could use on your engine is the case screws.
Not one bit will swap over to your engine.
You need bits from a 6v c50/70 or 12v c50/70/90 or bits from most pitbike copy engines.
