Parts for sale
- Rides:: CM 91 .. well kind of :)
Parts for sale
Some parts for sale ... If they are too expensive just say
Brand new CM 91 frame .. no numbers £300 no offers
C200 ... needs minimal welding underneath .. can come in various guises ( i.e as absolute bare frame and tank £130 add forks, speedo and front shocks £150 . Have got swing arm, front hub shocks to suit ... just let me know what you need. NO V5 for this bike but numbers are all there
6v engine with 2 barrels, a new piston and rings and an early carb and manifold £100 plus post
12 v motor ... has compression ... appears to have had a replacement barrel but has no stator, flywheel or clutch cover and will need a repair on head for exhaust studs .. £50
C50 LAE ( I think .... they fit the 12v square bars ) Parking brake switchgear x 2 .. 1 complete £35 posted and one missing a lever and a switch but a switch or donor switchgear will be included £27.50 posted
Side casings .... Lifan, zongshen and an old honda one ... could split or sell as one lot
Coils .... C50ac ... C90 c91 c200 £10 each plus post
Rectifiers C50/c100 cm91 c200 c90 £10 each plus post
CD 90 side casing £10 plus post
Stators and flywheels .... no idea what they are from. Medium sized flywheel has YX stamped on it ... £15 plus post
Carbs ... 2 x mikuni 22 mm ( copies i think ) plus have what i think is an original £25 plus post for the 3
C50 carb ( I think ) £12 posted
12v square lamp speedo 8k miles £10 plus post
12v square lamp seat bracket £5 plus post
LAC / 70c 90c seat bracket £10 plus post
Small oil cooler £15 posted
C90 front badge with light £5 plus post
Good c90 z2 / zz sidepanel £15 posted
Re: Parts for sale
Wheels are £275 a pair posted ... they are 1.6 x 17 and fit straight on a 12v Square lamper. They come complete with new brake plates, shoes, speedo cables etc
Re: Parts for sale
Just the common gear levers for sale .... £5 each posted?
12v bars £10 plus post
Inlet manifolds £7.50 each posted
Small seat bracket has had a weld ... no idea what any of them are off ... you tell me and make me an offer
Swingarm has been powder coated and has had new bushes £35 plus post?
c100 bars with switchgear £40 plus post?
standard 50 / 70 / 90 bars both in good nick £20 a pair
- Alan CF
Re: Parts for sale
how much for the two carbs,( picture of you holding both in one hand, looks like cg carbs,)
- bigswifty
- Rides:: Honda C90 M-G, Innova 125
Re: Parts for sale
Hiya,
C90 front emblem and light please, pay pay?
Please send payment detail cheers
Bigswifty
Bigswifty
Re: Parts for sale
Alan ... those carbs are the copies I think mate ... there are 2 of them plus what looks like a genuine top ... I was looking for £25 plus a tenner post for the 3Alan CF wrote:how much for the two carbs,( picture of you holding both in one hand, looks like cg carbs,)
- Alan CF
Re: Parts for sale
also interested in that stater on the left, the one with 4 off set fixing holes on the back plate.( i think the flywheel on the right goes with it ) ,
would you know the sizes of the carb slides ( outside diameter) and distance between the fixing holes, Thanks,
Re: Parts for sale
Will measure this afternoon AlanAlan CF wrote:also interested in that stater on the left, the one with 4 off set fixing holes on the back plate.( i think the flywheel on the right goes with it ) ,
- Rides:: STREET Cub
Re: Parts for sale
Looking 4 a 6 volt coil if u can help thx mark
