Hoarder having a clear out c100 c50 c70 c90 6&12 volt !
- krazy kev
- C90Club Clown!
- Rides:: 12V CUB HEINZ
Re: Hoarder having a clear out c100 c50 c70 c90 6&12 volt !
Do you have a 12 volt CDI coil
- r80rob
- Rides:: 73 c70 with c90 110, 72 MZ es250 and a r80!
Sorry Kev , most of what I've got left is 6volt
- Rides:: yamaha tz 125/250 most importantly c90
Hi Rob can you help, im new to C90 tinkering and need a few bits and bobs to finish my project or info on where to obtain the parts... not sure if to try and restore the original wheels which are well rusty or buy the pattern ones you see advertised? also i need the front light (parking light ) lens cover ,the small clear one that sits under the front light ,also the pilot jet in the carb is blocked to the max with a small piece of wire that i got stuck in there! idiot! wheres the best place to get a seat cover and leg shield?? any help will be greatly appreciated !! i will post a load of pics at some point...many thanks simon.
- r80rob
Hi , from what I've seen of others experiences I wouldn't bother with the reproduction wheels , the spokes work loose regularly and there's a 99% chance your brake plates won't match, I don't have a parking light but try a wanted add on here or on the Facebook page? Probably same for legshields although most people don't like posting them.
Carb jets are readily available cheap on eBay and you can get reasonable reproduction seat covers from the same place.
Get some photos up and welcome
Seat covers you need ;- yvon1061@hotmail.co.uk
Beautiful job reasonable price and made in the UK
TZ250 please pop your location in your profile so peeps can see if they are near enough to help
- fergus
- Rides:: '79 C70 ZZ plus others...
Hey Rob, do you by any chance have an upper front fork panel cover for a 6v? The one where the badge attaches to. I've a C70zz but I'm guessing others would fit too.
- r80rob
- r80rob
I do have a c70 one , think the one on the right is c70zzfergus wrote:Hey Rob, do you by any chance have an upper front fork panel cover for a 6v? The one where the badge attaches to. I've a C70zz but I'm guessing others would fit too.
Pm if you're interested
Hi wondered if you had a c90 frame you might want to sell?mines a a 6v zz i want to replace?? thanks simon
- r80rob
Sorry your out of luck no frames
