Tonight's offerings all priced at £5 unless otherwise stated ,
12volt rear gaurd
Random seat - was fitted to a 12 volt 90 £10
Possible single seat conversion for 12 volt 90 was fitted but will need some modification to rear so seat has something to rest on - block of wood was used on the bike I removed it from
12 volt tank , can't remember if sender works
Modern top box , no key but latches closed , needs a rub down and paint to make perfect £10
12 volt front springs £10
12 volt speedo
12 volt bar plastics , faded
12 volt indicators / horn switch
12 volt front light , rough
