Got some solid chaincases to fit a C90ZZ, i took all the rust off and cleaned them up, there is some pitting where the rust was bad. Been given a dusting of Zinc primer to stop further rusting. In grey at the moment so obviously need sanding and painting. But nice and solid, no holes. The bottom guard is worse off then the top as you'd expect.. closer to the road. But this also isn't as visible. Looking for £15, postage through Myhermes seems to be about £7 (2-5kg)
Pair of rear shock absorbers from a C90ZZ. Surface rusting, but should clean up with a scotch brite and elbow grease . Still springy
Looking for £10, bit heavier than the chaincase, comes out at about £9 through MyHermes (Edging over 5kg)
C90ZZ Chaincase and Shockers
- Rides:: CT90K4 1972
- Rides:: Honda c90
Re: C90ZZ Chaincase and Shockers
Have you still got chaincase for sale ?
Yup still here!
- Rides:: honda c90
hi have you got a swingarm for a Honda c90 6v swingarm for a Honda c90
- Rides:: 1999 ST1100. 1961 Match G3. 1978 CB550K3. 1981 C90ZZ, 1975 C90, 1984 C90, 1986 C
Hi, have you still got c90 rear shocks for sale?
- Rides:: 1973 Honda c90
How much for the chain case ? Thanks
Surprisingly, these are no longer available, since it was posted 5 years ago
