Honda Cub Parts For Sale, Engine and Bodywork!!!
fatboi567
Rides:: C90!!!!
Post by fatboi567 » Fri Jul 17, 2009 4:52 pm
For Sale
Numerous Honda Cub 50 / 70 / 90 parts
Forks, mudguards, swing-arm, engine parts, wheels, and many more.
Just phone to see if I have what you need.
Tel: 01522 887103
fatboi567
Rides:: C90!!!!
Re: Honda Cub Parts For Sale, Engine and Bodywork!!!
Post by fatboi567 » Fri Jul 24, 2009 4:37 pm
BUMP, anyone?????
Newtsalad
Admin & site janitor.
Post by Newtsalad » Fri Jul 24, 2009 6:40 pm
I need some bits off of a c90zz, clutch, kickstart etc. How about a red front mudguard for a 50, rounded type? How about a rear spindle assembly for a 50? Have you any C100 bits? Cheers!
Saltysnax
Post by Saltysnax » Fri Jul 24, 2009 7:39 pm
Do you have a cylinder head with ball bearing camshaft in good condition, for a 12volt Cub 90 engine please?
fatboi567
Rides:: C90!!!!
Post by fatboi567 » Fri Jul 24, 2009 11:14 pm
Will have a look for the bits for you tommorow, not sure on the c100 stuff though
Boyblunder89
Rides:: c90
Post by Boyblunder89 » Fri Jul 24, 2009 11:38 pm
do you have an older c70 big valve head?
thanks
Rico
Rides:: Cub90, CG125, GS500, Bimota YB10.
Post by Rico » Sun Aug 30, 2009 1:10 pm
I'm could do with a cub c90 head, the inspection covers on mine are seized, I don't have a valve spring compressor, and it's burning a shedload of oil! A set of rings or a new piston kit and a top end gasket set too. I'm assuming the rings are shot, although the bore is about perfect! Got any advice?
fatboi567
Rides:: C90!!!!
Post by fatboi567 » Sun Aug 30, 2009 6:39 pm
Will probably have a head, what year is your 90?
Rings are probably you problem cncerning the oil :)
Newtsalad
Post by Newtsalad » Sun Aug 30, 2009 10:45 pm
Rico wrote:I'm could do with a cub c90 head, the inspection covers on mine are seized, I don't have a valve spring compressor, and it's burning a shedload of oil! A set of rings or a new piston kit and a top end gasket set too. I'm assuming the rings are shot, although the bore is about perfect! Got any advice?
Advice? Yeah.
The tappet covers are cheap enough to replace. If they won't budge or the nut's are round off, put a cold chisel on the outer edge of them and give them a wallop. Remember, if they don't move, don't force them, GET A BIGGER HAMMER! :x :x :x :x :x
Fuzz
Post by Fuzz » Sun Aug 30, 2009 10:54 pm
Righty tighty ......Lefty loosy !!!!
