Handlebar Conversion Kit
This simple bracket allows you to swap your original handlebars for 22mm common motorcycle bars.
http://pages.ebay.com/link/?nav=item.vi ... 1148389716
The bracket is fully bolt-on and requires no major modifications.
- Rides:: Honda C90 1996 12V :)
Re: Handlebar Conversion Kit
Nice one........
Will it fit the 12v C90 ?
- digger06
shame the legshield has to be trimmed, but still, a nice bit o kit at the right price
- Alan CF
This is exactly what i thought the other daydigger06 wrote:shame the legshield has to be trimmed, but still, a nice bit o kit at the right price
is it because the steel plate need to be thicker to get the bars higher.
- Alan CF
What would the cost be for two plates but no handlebar mounts. they dont have to painted as i would tig them together.
or would higher risers be the answer.
- krazy kev
- C90Club Clown!
- Rides:: 12V CUB HEINZ
I think it will fit all cubs with the possible exception of the C100 & CM models. It depends on the gap between the 2 inner bolt holes.wehey wrote:Nice one........
The leg shield has to be trimmed to allow the steering to have full lock. The conversion plate fouls on the leg shield it only needs 10-15mm trimmed off the top to give it clearance.
When you remove the original bars you are left with the headstock lock nut which is all below the line of the leg shield.
This is was my simple / affordable solution which is pretty simple to install.
- Rides:: Innova and an Innova streetcub in bits
Mine arrived today. Thanks!
I'm just fitting mine up now.....it's a nice piece of kit and has allowed me an opportunity to sort out some of my nasty wiring
I will post up some pics when I'm done
- Rides:: Honda c90, GSXR 1000 K3
Are you still producing these kits? Cheers
