Engine Parts
- yellasei
- Rides:: nowt at the mo!!
Re: Engine Parts
price for the clutch and a new nut please.
- Rides:: Hondas, lots of them
Re: Engine Parts
Hiyellasei wrote:price for the clutch and a new nut please.
I've measured the clutch plates and they are 3.5mm thick (same as new). Clutch is clean, plates oiled, all ready to fit.
Clutch is £10.00
Nut is £1.94
Lock Washer is £0.96
Postage £6.60 recorded delivery.
- Rides:: Cub90, CG125, GS500, Bimota YB10.
Re: Engine Parts
Got a plain bearing cub90 head in decent nick? Bit of porting would save me the trouble, although standard would be preferable. How much inc. post to Hampshire? Gasket set, std rings or a piston kit?
Re: Engine Parts
I'll have a look, I might have a standard 90 head. No new rings or pistons. Have gasket sets (top end).Rico wrote:Got a plain bearing cub90 head in decent nick? Bit of porting would save me the trouble, although standard would be preferable. How much inc. post to Hampshire? Gasket set, std rings or a piston kit?
Re: Engine Parts
I've just sent off to Grampian motors for the rings and gaskets, they ain't arrived yet, but when they do, I should have a nice tight motor. If I don't, I'll be giving you a shout. Thanks. Got a rear square indicator stalk and some brake shoes?- that's all I need now to have it fully refurbished, apart from a few consumables- another soupdragon saved from death by kids!
- Boo
Re: Engine Parts
FAO Yellasei.....
Are you still in need? Just found this thread (I know it's months ago! ) and I have a 6v C50 piston. Any use?
yellasei wrote:do you have a piston from a 50zz?? i need one and it does'nt matter on the condition, for a template to machine a 70 piston to match my 50 head.
- Rides:: Cub James Enfield Bantam BMW
Re: Engine Parts
I could do with a complete C90 Head if you have one please contact me on r.farnsworth1atntlworld.com
- Rides:: C90 Africa Twin
Re: Engine Parts
do you have a complete working cub 90 engine & or a frame please- 07743922863 Rod thank you
- Rides:: Honda z50r with c90 engine, Beta EVO 250, fantic 240, kawasaki kt250, Suzuki X7
Re: Engine Parts
Hi, I was wondering if you still have any engine parts forsale?
I'm looking for a con rod/crank assembly or just the con rod for a 12v c90 engine.
Ross
Ross
- Rides:: C90ZZ and Ducati 748R
Re: Engine Parts
im after a carb top with the throttle slide in it, that goes to the throttle twist grip. My bike is a 79 90. can you help please?
thanks
neil
thanks
neil
