Had to Strike!
- Pjam
- SPAMMER!
Had to Strike!
Ok, after stupidly missing out on some stuff recently I've just struck a deal for 2 engines 2 wheels and a box of other C90 parts!
I know nothing about them? the guy doesn't even know if their 6 volt or 12 volt! I've got a hunch their 6 volt, Who cares for £60
Let you know more later
- Rides:: C90,Pit Bikes,Atc's
Re: Had to Strike!
im i negotitation on a 83 c50,which c90 engine would be a straight swap?-guessin' the 12 volt...
so if 1's a 12v dibbs
- herrod
- Rides:: C50 cd90z 600 Rotax flat tracker.
Re: Had to Strike!
nice one pjam,what will you do with them?
- Pjam
- SPAMMER!
Re: Had to Strike!
No idea! Interested?herrod wrote:nice one pjam,what will you do with them?
- herrod
Re: Had to Strike!
No no I just thought,If you know nothing about them its the perfect opportunity to take them to bits and learn?
- Pjam
- SPAMMER!
Re: Had to Strike!
Yes good point and I did have that in mind we'll see what we've got at the weekend I hope
- Boo
Re: Had to Strike!
An '83 C50 could be a C50C (12v imported from Feb '82) in which case the 12v C90 engine is more or less plug-and-play........HarrisoN* wrote:im i negotitation on a 83 c50,which c90 engine would be a straight swap?-guessin' the 12 volt...
....or a C50ZZ (6v imported to March '83) or C50L (single seat version of ZZ imported to June '83) in which case the 12v C90 engine will fit in, but you'd have to convert the bike's electrics to 12v cdi.
If you've seen a picture of it, external fuel tank means it's a 6v, enclosed tank means 12v.
A 6v C90 engine won't fit any C50 no matter what you do!!!
- Rides:: 77 C90
Re: Had to Strike!
If there's a C90 exhaust valve in the box of parts, can I buy it off you?
- matt.leese
Re: Had to Strike!
jamlip wrote:If there's a C90 exhaust valve in the box of parts, can I buy it off you?
http://cgi.ebay.co.uk/HONDA-C70-C90-ST7 ... 4cee0bd1c2
http://cgi.ebay.co.uk/HONDA-C50-C70-C90 ... 35a7ed3017
cheap and their genuine
- Rides:: 77 C90
Re: Had to Strike!
Not the same - the valve I need is 14721-028790
