honda c70 chaingaurds
joefish
Rides:: honda c90zz honda c90n
Post by joefish » Tue Mar 23, 2010 2:39 pm
new set of chain gaurds never been on a bike will fit a c50 or c70 they are for the 6 volt model they are the same as the photo on page 94 on the haynes manual 1967 to 1981 i bought them thinking they would fit a c90 but they dont
matt.leese
Rides:: 1995 red 107cc c90, 1979 blue c70 zz, 1985 c90 cub blue, 1971 c50, 1973 c70z2
Re: honda c70 chaingaurds
Post by matt.leese » Tue Mar 23, 2010 5:03 pm
joefish wrote:new set of chain gaurds never been on a bike will fit a c50 or c70 they are for the 6 volt model they are the same as the photo on page 94 on the haynes manual 1967 to 1981 i bought them thinking they would fit a c90 but they dont
any pics of the guard, im after one and if the the correct one ill take it :D
Boo
Post by Boo » Tue Mar 23, 2010 6:24 pm
If they fit a 6v 50, they're the same as the 70Z2 and ZZ, but not the earlier 70. (also fit C50, 70 and 90'C') basically all the 'short-shock' models.
joefish
Post by joefish » Tue Mar 23, 2010 6:41 pm
re boo they fit a 1979 c70 the do not fit a c90 as the c90 has a thicker chain therefor the chiangaurds are thicker also the mountings for them on the swingarm at the back is not the same as a c50 or c70 i found out the hard way i also thought they fitted a c90 thats how i have them
herrod
Rides:: C50 cd90z 600 Rotax flat tracker.
Post by herrod » Tue Mar 23, 2010 7:36 pm
how much?
matt.leese
Post by matt.leese » Tue Mar 23, 2010 7:49 pm
thanks for the e-mail joe but this gaurd its for the long shock type , cub 12v style swing arm. not for the short shock type :(
Boo
Post by Boo » Tue Mar 23, 2010 8:13 pm
joefish wrote:re boo they fit a 1979 c70 the do not fit a c90 as the c90 has a thicker chain therefor the chiangaurds are thicker also the mountings for them on the swingarm at the back is not the same as a c50 or c70 i found out the hard way i also thought they fitted a c90 thats how i have them
Just had a look at p94 of the Haynes.. those won't fit a 1979 anything!!! (or any 6v C50)
They'll only fit a pre-'77 6v C70 or, as Matt says, any square lamp model C50/70/90 12v, 1984 on.
If you've a 6v C90 nothing will do but a 6v 90 one (including Z2/ZZ)
Cub parts are rarely as simple as 50,70,90 or 6/12v!! :roll:
