1970 C50 /70 for sale - £1650.00
RE-OPENED! :)
bobber-job
Rides:: '70 C50 '72 Yamaha RT2 '74 Suzuki TS400 '94 Bullet 500 '66 Triumph TR6R + T120
Post by bobber-job » Fri May 11, 2018 4:39 pm
1970 6V C50 in Grey. 70cc conversion. Good solid frame though there is some surface rust. New head , cam, barrel, piston, valves, camchain, uprated oil pump (used) new clutch plates, HD clutch springs, gear shaft, gear selector, oil pump drive sprocket and shaft, engine bearings, seals, crank rebuild with new con rod, tyres, battery, C70 exhaust (used) + a few spares. Only 2 miles since rebuild. Still on the C50 carb but I have a new Chinese carb, pre jetted for a 70, to go on. It will be VHI eligible on the 20th. I bought it for £850 and spent £675.00 on parts. Its in Bristol
