Hello everyone!
Sorry to say but at the next Cub meeting I won't have a cub anymore as I want to sell it.
Here it is:
For sale Honda Cub C90 ZZ, 1981, 6V
I have changed the engine with a new Lifan 125. New exhaust and pipe, new suspension, 12V wiring harness bought from ebay and on the bike, extra headlamp and support for the 12V headlight, changed rear indicators, new wheel bearings, seals, swingarm bushes, new front fork bushes, new tires Michelin m45.
The 6v engine is running smooth, new piston and rings, I’ve done the run in of the engine, not to many miles with it after the run in as I have change to the lifan engine.
Other parts left:
6V wiring harness, stock rear dampers, 6V exhaust- kinda rusted, oil cooler with hoses and engine oil plate, and a second pair of hoses, longer ones.
The bike will require another seat.
The right cover for the battery compartment is damaged as seen in the pictures because of a previous pipe routing that burned the top of the cover.
The white engine cover is cut for intake room.
The lifan engine has bit of an issue, it won’t go over 30mph, and from what I’ve checked and read on the cub forum probably needs a clutch adjustment, haven’t done it yet but I want to check this as well. I’ve checked all wiring/ ignition, alternator, compression, carburetor, all is good, except that clutch thing.
On the clock it has 12600 miles – around 1k miles done with the lifan.
It has no MOT, road tax, insurance as I haven’t used it or couple of months
I’m selling them all as a pack for £900 ONO
Contact: 07778177412, or facebook.
More pics on c90 facebook
https://www.facebook.com/groups/2918484 ... 948215650/
C90ZZ for sale with extras! £900
Reason: It's Radu - enough said? :D
Re: C90ZZ for sale with extras! £900
Radu
A location will help the sale. I know you're near George but no idea where or I'd have added it for you.
I've added your price into the header.
Pretty sure he and it are in Coventry.Capitano wrote:Radu
