ST50/70 Dax and CF50/70 chaly 3 and 4 spoke wheels.
steveST100
Post by steveST100 » Mon Mar 12, 2018 6:52 pm
Few people have asked about the wheels on the ST and CF so thought i would put this bit together.
Some of the 3 and 4 spoke wheels i have for some of the bikes i'm building.
4 spoke wheels.
4 spoke front.
The 4 spoke was used on the ST50/70 in both 6v and 12v and the CF50/70 only in 6v.
Brake side,note the plate is on the left side and has screw on speedo cable.
Inside of hub and brake plate with the speedo drive in place.
Note upright tabs on the drive and slots in the hub.
Speedo drive.
4 spoke rear.
Brake side.
Inside of hub with brake plate.
Sprocket side.
Crush drive rubbers and rear sprocket removed.
Seal and spacer and you can see the groove for the C-clip that holds the rear sprocket on.
steveST100
Re: ST50/70 Dax and CF50/70 chaly 3 and 4 spoke wheels.
Post by steveST100 » Mon Mar 12, 2018 7:08 pm
3 spoke.
This was only used on the 12v CF50/70.
Front.
Note plate is on the left side.
Other side.
Brake plate.
Note push in speedo drive cable.
Inside of hub and brake plate.
Note the flat tabs on the speedo drive and raised bits on hub.
Speedo drive in plate.
Rear.
Inside hub and plate.
Sprocket side.
This hub was missing the seal,showing sprocket held on by the C-clip.
steveST100
Post by steveST100 » Fri Mar 16, 2018 5:33 pm
Rims.
4 spoke.
These have 4 smaller 6mm holes and 4 8mm holes.
There is only one bolt hole between the spoke webs.
3 spoke.
These have 6 6mm holes and 3 8mm holes.
There are two 6mm holes between the spoke webs.
Hub nuts and bolts.
The bolts are stock 8mm type but the nuts are a larger size than a stock 8mm nut.
Best to save the old nuts and have them replated.
Small size nut over the larger type.
Smaller stock nut in the larger hole that the hub nuts fits in.
Who is online
Users browsing this forum: Jc70dax and 1 guest
