Tuning my carb help!
Jmp
Rides:: 1970 c50
Post by Jmp » Mon Mar 13, 2017 1:28 pm
Hi, I have a Honda c50 with a race (road legal) exhaust, and the bike is running very lean as expected. There is two screws on my carb, one for idle, and the other the afr. Could I turn the afr screw to make it run a little better, and which way would I turn it? It's a KenJen Japan carb or something like that.
Thanks, JP
knapdog
Rides:: '95 C90 e/s, '11 CB1300, '09 NT700
Re: Tuning my carb help!
Post by knapdog » Mon Mar 13, 2017 2:09 pm
That'll probably be a Keihin though it may be a copy.
Im very general terms, the idle mix screw on the left you should turn inwards for richness and outwards for lean.
1 1/2 turns outwards should give you the "norm" but every set up is different due to the size and condition of the jets,
etc etc.
Post by Diesel Dave » Mon Mar 13, 2017 3:28 pm
Jmp wrote:Hi, I have a Honda c50 with a race (road legal) exhaust, and the bike is running very lean as expected. There is two screws on my carb, one for idle, and the other the afr. Could I turn the afr screw to make it run a little better, and which way would I turn it? It's a KenJen Japan carb or something like that.
Thanks, JP
The other screw is the IDLE mixture setting - doesn't change anything else.
Who is online
Users browsing this forum: No registered users and 3 guests
