Show us your Plop!!.....
Ventura
Rides:: '91 C90, '73 ST70 & Z50, '76 TL125, '80 Bultaco 250, '16 Yam XSR900,
Re: Show us your Plop!!.....
Post by Ventura » Sat Jan 21, 2017 6:28 pm
fazey wrote:Cool. I need to know how to do this mod, searched but couldnt find anything.
Seeing has i dont actually have a back brake pedal as yet it seems a good idea.
Anyone going to help me out here please :D
There's lots of different ways to do it Fazey.
If you look at the pic of my bike you'll about see what I did.
Basically I used the original rear brake rod, but turned the drum lever to point upwards instead of down.
Made an anchor point for the cable at the engine mounting bolt and used a C90 front brake cable to connect it all up.
Has worked fine for me so far! :)
V.
fazey
Rides:: retro's
Post by fazey » Sat Jan 21, 2017 7:15 pm
i can see the bracket but i have no idea how you are connecting it to the brake rod. have you got any closer pictures for me graeme.
Ventura
Post by Ventura » Sat Jan 21, 2017 8:29 pm
fazey wrote:i can see the bracket but i have no idea how you are connecting it to the brake rod. have you got any closer pictures for me graeme.
If you chop the bent end off the brake rod and put a thread on it, you can connect it to the threaded end of the brake cable with a long-nut.......
Thats the easiest way.
V.
Drew
Rides:: TZ Spondon 250
Post by Drew » Sat Jan 21, 2017 11:23 pm
Rear brake is easy to sort. Buy a rear brake cable off a scooter and a pair of motorcycle levers (all available on flee bay) levers about £12, cable the same.
Cable I purchased is 1800mm long ish, still a touch too long but shortest I could find. Make a cable stop from a piece of 90 deg angle (nice and strong!) and fix it to the rear brake torque arm in the correct place. Just drill a hole in the torque arm and bolt to it. Ditch the old rear pedal and metal rod route the cable job done!
I put a front brake arm (the bit the cable attaches too on the spline) on the rear as its longer than the standard rear therefore more leverage, because yer foot is stronger than the left hand pulling the brake. I have never been out braked into a corner!!
fazey
Rides:: retro's
Post by fazey » Sun Jan 22, 2017 12:02 pm
Thanks chaps i'm off up to workshop to see what i can come up with..
Timvmax
Rides:: Vmax
Post by Timvmax » Wed Jan 25, 2017 10:34 pm
I like the idea of the additional front shocks, what are they off? and more importantly, do they do any good? :D
blinkey501
Rides:: Aprilia mille Aprilia falco Benelli tornado tre was a honda 90 but now it's five
Post by blinkey501 » Sat Jan 28, 2017 2:34 pm
Are you aloud to put the front shocks on the 90's and 110's ?
culfy
Post by culfy » Sat Jan 28, 2017 4:34 pm
Yes you can Blinkey ,and to Timvmax they make a big difference when your on the track ,people have used various methods to stiffen the front end you are best to look at previous pictures from the other plop races .
culfy
Post by culfy » Sat Jan 28, 2017 11:42 pm
Just found this one from Anglesey ,I'm on the left
gil801
Rides:: c90
Post by gil801 » Tue Jan 31, 2017 7:31 pm
I've invited the father in law to mallory...the wife thinks I'm just being a great hubby. However I didn't get one photo of me from Anglesey and he's a mad keen photographer. Needs must eh.
