plop project
Vxnath
Rides:: Honda c90
Re: plop project
Post by Vxnath » Mon Mar 13, 2017 11:41 am
What diameter did you go for?
fazey
Rides:: retro's
Re: plop project
Post by fazey » Wed Mar 15, 2017 5:34 pm
hi
The one i got was to fit a 28mm end can.
This one...
http://www.ebay.co.uk/itm/272484292036? ... EBIDX%3AIT
fazey
Rides:: retro's
Re: plop project
Post by fazey » Sat Mar 18, 2017 4:43 pm
Well finally she's done.
culfy
Re: plop project
Post by culfy » Sun Mar 19, 2017 3:02 pm
Looking good fazey ,as they say "See you track side" :D
The Chicken Chasers
Rides:: ZX9R, RD500LC, RG250III, RS125SP, WR450F, TC250, REV3 250 and 2 Cubs!
Re: plop project
Post by The Chicken Chasers » Thu Mar 23, 2017 12:27 pm
Looks great, but your foot pegs are way too low. They'll touch down at the first sight of a corner, we tried some like that, they nearly chucked me off on the first test ride round the block
fazey
Rides:: retro's
Re: plop project
Post by fazey » Thu Mar 23, 2017 9:12 pm
Footpegs are at the welders being moved up an inch. i did touch the footpegs down when we took it for a test.
Where did you get other higher footpegs from ? just incase the ones being welded dont work.
I have some original ones but the holes are in a different position on a lifan engine.
I will also have to weld the gear lever as i wont be able to get the bolt in if i lift it higher.
culfy
Re: plop project
Post by culfy » Sat Mar 25, 2017 8:20 am
You can put the bolt in from the other way (one a bit longer ) then put a nut on it on the back side and it will still tighten up .
fazey
Rides:: retro's
Re: plop project
Post by fazey » Sat Mar 25, 2017 10:41 am
Did think about that Ian but was worried some aggressive gear changing might knacker the splints. Have had it cut and welded the other way round.
culfy
Re: plop project
Post by culfy » Sat Mar 25, 2017 8:26 pm
Ok pal ,as long as your sorted ,6 weeks today :D
fazey
Rides:: retro's
Re: plop project
Post by fazey » Tue Mar 28, 2017 4:44 pm
this so much better..
