plop project
Re: plop project
Post by Diesel Dave » Tue Jan 31, 2017 12:18 pm
Scruitineering must be lax.....could take a large chunk out of your leg :D
fazey
Rides:: retro's
Re: plop project
Post by fazey » Tue Jan 31, 2017 10:10 pm
just a prototype for now ventura. need more of a sharp 45% to get the cable more tighter to the frame.
the sharp edge,s will be rounded off before we go. out thats for sure!
steveST100
Re: plop project
Post by steveST100 » Wed Feb 01, 2017 12:29 am
Another way may be like this,not mine just a photo i saved.
The Chicken Chasers
Rides:: ZX9R, RD500LC, RG250III, RS125SP, WR450F, TC250, REV3 250 and 2 Cubs!
Re: plop project
Post by The Chicken Chasers » Wed Feb 01, 2017 11:27 am
You're better off mounting the cable bracket to the swingarm or brake torque arm. With it mounted to the body like you've done it'll change the cable tension as the suspension moves, which is bad
Ventura
Rides:: '91 C90, '73 ST70 & Z50, '76 TL125 x2, '73 Yam RD350, '06 Scram, '16 Yam XSR900,
Re: plop project
Post by Ventura » Wed Feb 01, 2017 12:32 pm
The Chicken Chasers wrote:You're better off mounting the cable bracket to the swingarm or brake torque arm. With it mounted to the body like you've done it'll change the cable tension as the suspension moves, which is bad
It doesn't tho.
So it's good! :)
V.
fazey
Rides:: retro's
Re: plop project
Post by fazey » Mon Feb 06, 2017 8:09 pm
Well an updated version and im pretty happy with it.
Plus a bonus, i bought the exhaust from e bay for a pit bike for £15 new (on a wimm) and f*** me it fits, albeit i will have to get the last 300mm bent so as not to burn my ass. plus add a silencer.
so for less than 20 quid i got 2 things sort.. happy :D
fazey
Rides:: retro's
Re: plop project
Post by fazey » Mon Feb 06, 2017 8:11 pm
Vxnath
Rides:: Honda c90
Re: plop project
Post by Vxnath » Thu Mar 09, 2017 12:50 am
I am liking this project. What size exhaust did you go for?
Plus do you have any more close ups of your rear brake set up pls. Want to do this my self, but trying to get a look at others first!
Bike looks dead smart tho!
fazey
Rides:: retro's
Re: plop project
Post by fazey » Sun Mar 12, 2017 11:37 am
Bought the exhaust from ebay for £15 then cut and welded the end of it so it didnt burn my ass then added the end can also from ebay for £10
Just search for pit bike exhausts.
If you read back you should be able to make sense of the back brake mod. it was pretty simple really.
Happy with the way the exhast works and looks. :D
Drew
Rides:: TZ Spondon 250
Re: plop project
Post by Drew » Sun Mar 12, 2017 4:58 pm
I see an issue with this back brake setup, the rod will be moving up and down with the suspension continually pulling or pushing the brake arm. Effectively shortening or lengthening the rod, could make lever adjustment difficult
The brake arm only needs a few mm of movement when adjusted correctly and theses bikes really rely on the rear brake in plop as the front is so poor.
I've taken a cable to the rear brake torque arm and fixed the cable stop there hence the distance between cable stop and brake arm is constant. Works a treat and I've never been out braked! Yet!
