1974 C90 for possible p/x
Swap your parts and WHY here
DogRustyJunior
Member formerly known as Swamper
Rides:: 1974 C90
Post by DogRustyJunior » Fri Nov 06, 2015 5:26 pm
Hi all,
I'm thinking about maybe getting something a little newer,or a little bigger,and given that C90s are like currency at the moment,thought I would pop a little ad on here :)
Facts:
1974 (tax exempt though logbook needs updating at post office to reflect that) Elephant Grey C90.
One of the last with the torque arm anti dive front suspension.
Genuine mileage of under 7000.
NO ROT,never welded,never patched,usual rust pockmarks bleeding through the paint but no corrosion whatsoever,bike was garaged and off the road from 1982 until last year.
New exhaust,top end decoke,Michelin m45 tyres,new old stock rear rack with pannier brackets,pannier bags and period fibreglass Rickman top box.
Halogen headlamp,LED rear lamp (bright as the headlamp!),led sidelight.Proper earth wires added to indicators and headlamp.Correct pressed metal number plate,small tear at rear of seat cover.
Oil changed every 500 miles.I've done 3000 miles on it every day since March.
One extra tooth on the front sprocket,holds 45 easily,will sit at 50 in good conditions.
Averages around 135 mpg
MOT until end of March 2016.
Thinking of maybe a townmate,jahova(!) Or similar
Just throwing it out there and see what crops up
stevew
Re: 1974 C90 for possible p/x
Post by stevew » Fri Nov 06, 2015 6:25 pm
Townmate won't be much different Innova a little quicker :?
Why not think about a CG125 brilliant little machines that will actually overtake trucks on the main roads
DogRustyJunior
Rides:: 1974 C90
Post by DogRustyJunior » Mon Nov 09, 2015 2:03 pm
I cant do it,i love the thing too much! :D
Post by Diesel Dave » Mon Nov 09, 2015 3:58 pm
Keep it, there's little to be gained by swapping and the chances are you will always regret it.... :D
George
Rides:: 2000 C90T; 1998 C90CWV; 1997 C90T; '16 Africa Twin CRF1000L
Post by George » Mon Nov 09, 2015 5:04 pm
Diesel Dave wrote:Keep it, there's little to be gained by swapping and the chances are you will always regret it.... :D
Like!
RoadCar
Post by RoadCar » Tue Nov 10, 2015 11:21 am
You could sell the Velocette and buy a Innova or similar. Use to 90 for weekend bimbles pretty much all I use mine for :)
