Valve spring compressor
Swap your parts and WHY here
krazy kev
C90Club Clown!
Rides:: 12V CUB HEINZ
Post by krazy kev » Sat Nov 29, 2014 9:14 pm
I have a valve spring compressor that I am willing to swap for a good 12v 90 crank and suitable kick-start shaft assembly for a Chinese 4 speed gearbox.
The valve spring compressor has only been used once. It enables you to remove the valve springs on almost all petrol and diesel car engines without removing the head allowing you to change the valve stem seals
Tug
Rides:: triumph Bobber, DR 400, CG, c90 xs 650 street tracker
Re: Valve spring compressor
Post by Tug » Wed Dec 03, 2014 6:15 pm
Kev
I have a c 90 bottom end you can have the crank
Tug
