Page 1 of 5
32mm stainless header pipes
Posted: Sun Nov 13, 2011 7:33 pm
by mteck-racing
stainless header pipe for the honda cub/c90.
will fit all of the cub range
but not the early 6 volt c90 that has points in the head.
It is 32mm o/d 1.5mm wall 304 stainless steel with a steel laser cut mounting flange.
will fit without any modifications to the bike.
also will come left long so you can cut down. about 7" past kickstart
£35 with free post to forum members (To uk only)
as of today 12.11.11 i have 10 in stock
A few pics of exhausts i have made using this header -
I can also make one off header for eg a pit bike yx160 engine
Re: 32mm stainless header pipes
Posted: Sun Nov 13, 2011 11:13 pm
by dread
so long as they fit the pit bike engine (125/140) and let it breath put me down for one. thursday. might as well be broke again. LOL.
bloody projects. HAHAHAHA.
Posted: Sun Nov 13, 2011 11:14 pm
by dread
oh do they come with brass nuts and washers for the zaust header.
Posted: Mon Nov 14, 2011 11:47 pm
by mteck-racing
NOTE - as a guide for pit bike engines.
If the std cub footpegs fit and so will this header.
If not than i can make you a one off header.
Posted: Tue Nov 15, 2011 12:44 am
by dread
looking into it pal.
have sent linky thinky. for picture
http://i62.photobucket.com/albums/h104/ ... re2373.jpg
Posted: Fri Nov 18, 2011 10:20 pm
by dread
Posted: Fri Nov 25, 2011 10:46 pm
by mteck-racing
Down to my last two headers. so if you want one pm me.
also i have a full kit in stock (yoshi type)
Posted: Fri Dec 23, 2011 5:33 pm
by Blackcountry Pete
Ive just received a second pipe ordered from Mike i honestly cant recommend these enough absolutely fantastic.
BCP
Posted: Fri Dec 23, 2011 9:26 pm
by Pjam
Just trying to make the silencer fit with it though! Could be the extra width from the YX125 causing problems?
Posted: Fri Dec 23, 2011 9:41 pm
by dread
is it a 35/36 , mine is a 34. so be cutting a couple if not 3 groves in the inlet side of the can ,
paypal order will be going in on the 29/30 at long last. so many bits to buy, and not anough dosh to do it, ant life a bitch.
