Early Hondas. (pre 'C')
- Boo
Interesting mid 1950s Honda. Not sure what model, but it's from before the C## model naming system started.
Re: Early Hondas. (pre 'C')
SB 350 dream single....?
- LeVelo
- Rides:: C90E(stock) C90G(125) C90ZZ(140)
i think it's a Dream ME
look at the thickness of the castings, and winterproofing bits like the bellows between the engine and the chainguard. man, they wanted these things to keep going forever.
- Pjam
- SPAMMER!
Very British. Gear change on the right, rear break and chain on the left. Nice pedestrian slicer too Also, since we were looking at leading/trailing links, what's going on there?
- digger06
they will be,,, a lot of designers came from the british bike industry to go work for japan,a lot were almost identical copys to brit stuff, you could swap parts from a kawi 650 with bsa bikes at one point!!!Pjam wrote:Very British. Gear change on the right, rear break and chain on the left. Nice pedestrian slicer too Also, since we were looking at leading/trailing links, what's going on there?
Yes Le velo gets it 1953 dream ME
- LeVelo
Just asspulling this, and I'm often wrong while sounding totally plausible...Pjam wrote:Very British. Gear change on the right, rear break and chain on the left. Nice pedestrian slicer too Also, since we were looking at leading/trailing links, what's going on there?
but I think they've cloned the Douglas Radiadraulic, and those great big castings at the fork ends are actually oil reservoirs with damping valve adjusters on the back
- Pjam
- SPAMMER!
It could be the very same.
That looks good and functional LeVelo, and of course, a new one on me. Nice. Amazing you should know these things
- Boo
That's the brake on the right just like a modern Honda. Heel & toe gear pedal on the left. The British style bit is having the chain on the brake side.Pjam wrote:Very British. Gear change on the right, rear break and chain on the left. Nice pedestrian slicer too Also, since we were looking at leading/trailing links, what's going on there?
I was thinking they look like some sort of horizontal dampers at the bottom of the leading link castings, so that's very interesting LeVelo.
- Rides:: Suzukii Address i 2010,Honda 300i 2007
Yes very interesting front forks,my guess is the section at the lower front of the forks is a valve/reservoir dampener
Tom
Tom
