ANF 125
detector2000
Rides:: Yamaha Majesty 400 Honda ANF 125.
ANF 125
Post by detector2000 » Sun Jun 05, 2011 7:27 am
I have now done a deal for a Honda ANF 125, just a bigger c90 to me and runs well, but on the clock face is gear numbers 1 to 4 that should light up but they dont? anyone know of a fix for this? many thanks. Rob.
Pjam
SPAMMER!
Re: ANF 125
Post by Pjam » Sun Jun 05, 2011 8:04 am
Sorry, I don't. My ANF has been well behaved so far, but I have heard of something similar before. The other problem with them is that sometimes it thinks the side stand is down and that in turn cuts the igition!
Last I heard manuals are hard to come by, if you find out different please let me know ;)
Also don't thrash too much, I find it cooks the oil! and I've yet to find a dedicated oil cooler.
Newtsalad
Admin & site janitor.
Re: ANF 125
Post by Newtsalad » Sun Jun 05, 2011 12:22 pm
detector2000 wrote:Honda ANF 125, just a bigger c90 to me
:o :o :o :o :o Heresy!!!! :lol: :lol: :lol: :lol: :lol: :lol: :lol: Have you owned a 90?
Newtsalad
Re: ANF 125
Post by Newtsalad » Sun Jun 05, 2011 12:24 pm
And no, I haven't owned a 'Jehova'. I have ridden Bogger's though, does that count? :?
They're good bikes, true. It does seem that folk with both, and there's quite a few, don't really see them in the same light.
ll81
Rides:: CBF125 Z250SL
Re: ANF 125
Post by ll81 » Sun Jun 05, 2011 4:13 pm
I like mine alot, It aint no cub though.
Lack of manual is a problem, A BIG PROBLEM HAYNES!!!!. There's a very good chance neutral and all gear positions are send via a datastream single wire system to the instrument panel. Wiring looms are getting thinner as it's silly to use 5 wires when one will do, they may well have done it the old fashioned way but who knows. If it is a bunch of wires try earthing them out and seing if you can get the gear position cluster to light up. If mine ever fails I'll post the result, but as it's not even a year old I don't think that's going to happen any time soon.
Only ever advise I can offer is the usual termianl and connector check. Corrosion, broken wires, that sort of thing
detector2000
Re: ANF 125
Post by detector2000 » Fri Jun 24, 2011 7:14 pm
All sorted it was the change switch up the shoot, £15.00 from lings honda and all working ok. Rob.
Pjam
SPAMMER!
Re: ANF 125
Post by Pjam » Sat Jun 25, 2011 9:57 am
Very glad it's sorted :) I'm dreading any failures on mine because as 81 says ....... No Haynes! and Cub knowledge doesn't really apply.
Where is this switch detector? I'm trying to learn from your experience ....... sounds like you've been working on your own :geek:
detector2000
Re: ANF 125
Post by detector2000 » Mon Jun 27, 2011 8:35 pm
Hi the switch is located left hand side of engine next to the gear lever you have to take the plastic cover that hides the front sprocket off to bolts and it sits on the side of the crank case just 2 10ml bolts and it slips off disconect the terminal block and fit new, i find it easy to work on just like a c90. Rob.
Fuzz
Re: ANF 125
Post by Fuzz » Mon Aug 29, 2011 6:40 pm
You can as numerous owners have done , just resolder the connections & refit!
Tackleberry
Rides:: Modified '99 ZX7R, '09 CBR600RR Ltd Edition, '02 DRZ400, '00 C90E, '97 C90E
Re: ANF 125
Post by Tackleberry » Mon Oct 31, 2011 9:47 pm
hmmmm... just bought a 2006 last of the carbed Innovas and I was hoping finding a manual wouldn't be such a mission. Can't find anything on-line unless it's in bloody Thai. (Honda Wave 125 is the same)
Anyone got any linkies to manuals?? I just want to do valve clearances and a full service - would rather not trial and error it.
