Innova 125 ANF Drive chain 2008
midget
Rides:: anf 125 +sh300i
Post by midget » Tue Jul 25, 2023 11:41 am
Hi
Anyone had problem with drive chain clattering inside case?
Have adjusted correctly, but still noisy.
Devon general andy
Re: Innova 125 ANF Drive chain 2008
Post by Devon general andy » Tue Jul 25, 2023 11:58 am
Need to separate them to see which half is rubbing. Look for wear marks inside aswell.
There's not a lot of clearance inside. Only takes small bend, ding or out of alignment to rub.unless your chain is extremely worn and the slack up and down movement is catching in the bottom. Need to check play in sprocket carrier and sideways float on drive sprocket.
You've checked axle alignment on marks... haven't you?
Cheers Andy.
dmw1950
Rides:: Enfield Hunter 350/CB125F/Silverwing 600/Vespa250GTS
Post by dmw1950 » Tue Jul 25, 2023 1:49 pm
I did have trouble, the case was not fitted back correctly by me, it has a lip which fits inside the other half. Take it off and refit.
