strokers
barker
Re: stokers
Post by barker » Wed Jan 26, 2022 10:59 pm
i will remember that tip bern you make it sound so simple john boy,i will have to start useing this new measurment its to hard in pints and gallons
125erCrazy
Rides:: C125 Super Cub/Address 110
Re: stokers
Post by 125erCrazy » Thu Jan 27, 2022 10:02 am
Trust me your not alone, the number of times I've calculated building materials and towards the end realise I've gone from metric to imperial at some point leaving me short
Thunderguts
Rides:: Cub
Re: stokers
Post by Thunderguts » Tue Feb 01, 2022 2:06 pm
As mentioned, just get a mixer bottle. It has a capacity line, then extra lines above it for different mix ratios; you just top it up to the relevant one. It's still pretty approximate but it means you can mix it thoroughly before it goes in the tank.
Mixing units, for anything, is never a good idea. For fuel ratios, stick with metric as it's a simpler relationship to work out (in my head) unless you're talking big quantities to make the measurements linear, e.g. 1 pint of 2-stroke mix in 8 pints (a gallon) of fuel.
Bern
Rides:: Virago 535 & Innova 125 (injection) & 1962 Ariel Leader
Re: stokers
Post by Bern » Tue Feb 01, 2022 3:22 pm
Re: stokers
Post by Capitano » Tue Feb 01, 2022 9:38 pm
The easy way ...... https://www.toolstation.com/al-ko-2-str ... lsrc=aw.ds
That's the one my Dad uses for his chainsaws.
Why he needs four different petrol chainsaws, all with a different petroil mixture (15:1, 20:1, 25:1 and 40:1) at the age of 87 is something I can maybe relate to, but my Stepmother can't get her head around. :lol:
Devon general andy
Re: strokers
Post by Devon general andy » Wed Feb 02, 2022 1:14 pm
That mix bottle is even cheaper than the one I found! Just make sure before you buy or order that it has the marked out ratios that you need!
By far the best way to go. Too many engines were ruined or had their life's shortened, years ago, by really vague measuring or even guessing. I remember when I got my first bikes with 'autolube' circuits, just fill the reservoir and off you go.....what a godsend.
barker
Re: strokers
Post by barker » Wed Feb 02, 2022 6:23 pm
i have chain saws and strimmers both are differant mix,i remember years ogo we just guessed how much oil to add to our 2stroke moter bikes. it was awonder the driver behing us could see were they were going , with all the smoke,
afraid them days are gone. you cant get away with it now im surprised gangas karn has not band all two strokes .mowers strimmers hedge cutters, he will ban smokeing in london soon,
Bern
Re: strokers
Post by Bern » Wed Feb 02, 2022 8:07 pm
In the days of yore forecourts had a gallon pump can with an adjustable ration plunger, set the ratio you want & added one 'shot' per gallon of fuel, another idea that never caught on was the measuring cup in the tank cap as used by MZ
Newtsalad
Admin & site janitor.
Re: strokers
Post by Newtsalad » Wed Feb 02, 2022 9:07 pm
And DON'T be tempted to add a little extra! :shock:
'Twill do no good, and can destroy your engine! aliengravy's grandfather did so with an expensive outboard engine. The excess oil gummed the rings into their grooves, and led to a very expensive repair! So be warned!
