Just Bought An Innova ANF 125
onittino3
Rides:: Honda C90, Honda innova
Re: Just Bought An Innova ANF 125
Post by onittino3 » Tue May 29, 2018 10:16 pm
lucky wrote:
Tue May 29, 2018 7:08 pm
wightegi wrote:
Tue May 29, 2018 5:14 pm
Put some holes in the collar in the filler neck and fill it up to the top ,the collar is about as thick as a bean tin so a sharp screw driver and a tap with a hammer will do the job. The collar is there to prevent the fuel leaking when it expands in the hot weather , 30 degrees plus :roll: :lol:
Thanks for the tip :) the only thing that bugs me is if I catch the side stand, when changing down gears my bike cuts off :evil: thinking about wrapping a bungy cord round it :) .
Your have real trouble catching the stand, when changing down ive got size 12 feet and ive never managed it, also the stand has to go quite far before it cuts the engine, safer to leave it working.
Tranberg
Rides:: Anf125i
Post by Tranberg » Tue May 29, 2018 10:58 pm
You're doing it wrong
Harry Notts
Post by Harry Notts » Wed May 30, 2018 4:53 pm
I have a 2004 model and the connector block is up close by the ignition coil. One green and white wire and one plain green.
Tranberg
Rides:: Anf125i
Post by Tranberg » Wed May 30, 2018 6:35 pm
What are you doing to it?
I think you are missing a return spring, or it's a wrong one.
Are you using your toe to downshift?
You do not want it running on the side stand in gear, only to see it lurch forward and crash
lucky
Rides:: (2001) X Reg Honda Cub 90 MT (Stolen) 2007 Honda Innova ANF 125
Post by lucky » Wed May 30, 2018 7:36 pm
The side stand is working fine & yes I do use my toe on the downshift, almost 6 years on my C90 and I never could master the heel & toe :) . I put a cable tie on it today as I always use the centre stand anyway, and no problems coming home tonight just have to remember I have 4 gears now :) .
gzk6nk
Rides:: Innova, Griso 8V, Freewind
Post by gzk6nk » Wed May 30, 2018 9:32 pm
Some years ago a guy with a lovely shiny Harley came out of a dealer in Manchester to his parked bike. I commented how smart it looked and he replied he wanted to trade it but the dealer hadn't offered enough. He climbed aboard, fired up, and rode off.
Just up the road he leaned the bike over to take the left at the lights. Crash bang wallop screech! The shiny bike was now a sorry sight as it lay in the road badly smashed. Yes, he'd left the side stand down.
Never, ever, even think of disconnecting your side stand switch except perhaps as a very temporary 'get you home' fix if it fails.
lucky
Post by lucky » Thu May 31, 2018 8:52 pm
I'll leave it on and just take the cable tie off when I get it MOT'd :) .
Tranberg
Rides:: Anf125i
Post by Tranberg » Thu May 31, 2018 9:24 pm
Your gear lever is either turned 2 or 3 splines to far clockwise or is the wrong type for an Innova.
This is how it's supposed to be, and there's about 2 inches from the heel pedal to the side stand.
lucky
Post by lucky » Thu May 31, 2018 10:33 pm
Here is my 2007 Honda Innova ANF 125 I guess looking at both gear levers, it was down to my clumsiness in missing the lever & catching the side standn :oops: .
lucky
Post by lucky » Thu May 31, 2018 10:40 pm
From the other side :) not in a bad condition .
