Troubles with my Kayak SuCu 110
Posted: Fri Apr 20, 2018 5:37 pm
by DonS
Today when going with 50mph on the highway it suddenly made a decent clonk and metallic noise.
Vibrations were felt in the engine.
I stopped, checked, and engine and gearbox worked ok.
So i drove home.
Then i noticed that the e-start is not working anymore. I can kick it on but no e-start.
When pressing the start-button i can hear the relais click but the starter motor is not working.
What happened? I didn’t touch the starter-button! Is it possible that the starter had a short circuit an engaged by it’s own?
How much damage might be done? Starter broken shouldn’t be too much a problem but if the starter sprocket is damaged i’m not willing to disassemble the whole engine.
No time and nerves for that right now.
Any suggestions?
Re: Troubles with my Kayak SuCu 110
Posted: Sat Apr 21, 2018 9:11 am
by DonS
Can‘t attach a picture (file too large) but i had the starter-motor off and it’s completely ruined inside.
Metall parts are broken and the copper coils burnt and distorted. Black dust and crumbs too.
Rest of the starter system seems to be ok.
Now the question is if a starter for a C90 will fit.
Monday i’ll call the german dealer and ask for starter and cover-gasket.
Posted: Sat Apr 21, 2018 9:27 am
by bikerbaker
Think the starter motor is quite a bit longer, there is a "bubble" in the legshields to accommodate it.
Good luck!
Posted: Sat Apr 21, 2018 12:38 pm
C90 version is a bit underpowered for turning over a 110.
Pit bike starters are cheap and available on eBay.
BUT you would be best to find out the electrical fault that caused it to turn on first.
Posted: Sat Apr 21, 2018 3:19 pm
by DonS
Thanks, i’ll kick out the starter-relais first. The relais might be the culprit.
Maybe it doesn’t separate the contacts as intended.
I don’t think it’s the starter button for it’s only working when the frontbrake-lever ist pulled.
Posted: Tue May 15, 2018 1:47 pm
by DonS
Ok, i replaced the broken starter motor with a new one.
Luckily i found a shop selling Quads and Cross Bikes in Austria. They’ve many parts fitting the chinese Cub’s. The new starter (chinese brand too) looks and sounds far better then the original one. A new starter relais completed the repair. Working perfect again.
With six bikes in my garage i reluctantly decided to sell two of them. I sold the SuCu and one of three Innovas.
To be honest, the SuCu was always much too small for me (6’2”), so sadly it had to go.
