Speed/RPM
raybarber
Rides:: Honda SH300
Speed/RPM
Post by raybarber » Tue May 09, 2017 10:15 am
Does anyone know or is there a way to calculate, what the speed/rpm is on a FI Innova please?
Andrewwoey
Rides:: CM91, plus many others in the garage.
Re: Speed/RPM
Post by Andrewwoey » Tue May 09, 2017 11:09 am
There is a post in another section regarding a cheap self powered rev counter. For a few pound it will tell you what you need to know.
Newtsalad
Admin & site janitor.
Re: Speed/RPM
Post by Newtsalad » Tue May 09, 2017 11:24 am
Depends on the gear ratio, final drive ratio, and rolling circumference of the tyres.
Maintenance Stasi
Rides:: 3 x C90,BMW R1200st, BMW R80RT, Honda Mode , Super Cub C125A, Yamaha Majesty 250
Re: Speed/RPM
Post by Bogger » Tue May 09, 2017 11:30 am
When it seizes up you know you've exceeded the rev limit. Or then again it could have been the oil you were using. Please feel free to ask away about what oil to use.
Bogger :|
JohnS
Rides:: .2019 Honda C125
Re: Speed/RPM
Post by JohnS » Tue May 09, 2017 5:39 pm
Have a look at item no.6913280449800 on eBay.They are very simple to fit and work as soon as the engine starts.I bought one from China,had too wait 4 weeks to get it but it was under fiver posted.When it arrived the leaflet said you can get them with a replaceable battery,but mine wasn't.So check them out.
Tug
Rides:: triumph Bobber, DR 400, CG, c90 xs 650 street tracker
Re: Speed/RPM
Post by Tug » Fri Jun 02, 2017 9:00 am
Bogger :|
what oil would you suggest?????
Maintenance Stasi
Re: Speed/RPM
Post by Bogger » Fri Jun 02, 2017 1:22 pm
Ah thank you for the invitation to reply :P . There are many oils on the market today, however my preferred viscosity is 5/40 fully synthetic. Make of oil, in my opinion, is immaterial. Please feel free to join in everyone :D .
ANF.S
Rides:: Honda ANF125 (2007 Carb model)
Re: Speed/RPM
Post by ANF.S » Fri Jun 02, 2017 1:28 pm
Why 5/40 sir when Honda manual says 10/30?
Maintenance Stasi
Re: Speed/RPM
Post by Bogger » Fri Jun 02, 2017 1:51 pm
Simply because I know better than Honda. 30 weight is too low a viscosity for the Cub engine.
Bogger :D ;)
Harry Notts
Re: Speed/RPM
Post by Harry Notts » Fri Jun 02, 2017 4:06 pm
What's voscistity,viscucity, vitycosity? Is it something to do with thickness ? Mrs Harry say's I have a high viscosity...should I be worried?
