Innova ignition lock position
- raybarber
- Rides:: Honda SH300
Excuse my ignorance but what does this do? When I turn the key that way, it won't come out, so I'm not sure what it's purpose it.
Re: Innova ignition lock position
turn it what way
- raybarber
The opposite way to on (ccw). It says "lock" on the barrel.
- Vk/Leeds
- Rides:: Suzuki uh200
Turn the bars to full left lock position then turn the key to lock position to apply the steering lock , then the key should remove from the ignition leaving the bars locked ! !
I'd always chain too to an object be on the safe side mind ! !
Cheers Vk. .
Cheers Vk. .
- raybarber
Thanks Vk so easy when you know how.Vk/Leeds wrote:Turn the bars to full left lock position then turn the key to lock position to apply the steering lock , then the key should remove from the ignition leaving the bars locked ! !
Cheers Vk. .
