Handlebar weight removal
- Rides:: None at present
So I'm trying to remove the screw from the bar end weights on the inj innova......( to fit handguards ) they spins so grips applied and screwdriver turned. Bloody solid.....bust the first screwdriver then bust a screwdriver bit.
Don't think there seized.
Any ideas?
Any ideas?
Re: Handlebar weight removal
Is there an expanded diagram on a spares site like Fowlers?
Those have helped me in the past see things I couldn't understand, looking from the outside.
There is a welded captive nut inside the bars and this is what the screw threads into, they are prone to seizure as the bars are a sealed environment with moisture inside.
Your going to have to 'beast it out' to use the modern Army parlance and then re-weld in a captive thread to refit the weights.
Not an easy fix, but would have been made sooooooo much simpler had lube been used on the threads during assembly.
Cheers Dave.
Don't know about the Innova but the Wave isn't like that.
It's a long weight with rubber expanding bits at each end. Couldn't undo the long bolt that goes through but i found that if i wiggled the visible bar end with a well attached pair of moles i could feel the give as the rubber squidged. Some GT85, some persistence and some gentle encouragement with a small hammer in the outward direction got them out.
Cheers Stevew.......every bit of advice helps.
Cheers Capitano...... I'll take a look.
ANF125 inova like most honda's has a separate weight rubber and a single clip mount inside the bars into which the bar end screws
Not sure this link will work fro you as I use trade site
https://www.fowlersparts.co.uk/parts/47 ... r-switch-2
It worked for me so I'm guessing it will, Alan.davebike wrote:ANF125 inova like most honda's has a separate weight rubber and a single clip mount inside the bars into which the bar end screws
Saved me searching and posting the link, too. Cheers!
Cheers Davebike.......that's a great help.
Had a look at a YouTube video....this fella post some very good tutorials on the inj innova.....
https://youtu.be/6I87lZgMmvg
Shows you everything other than removing the screw.
Cheers all.
Cheers all.
