Most likely proves a pointCapitano wrote: I don't see any recommendations
Heated grips that work well on a small bike ??
Re: Heated grips that work well on a small bike ??
- Vk/Leeds
- Rides:: Suzuki uh200
I used the velcro Oxford hot hands with my muffs ! !
They do work well , but add a little girth on the grips and only one set temperature , but once you get used to them they are fine .
All the connections were under the seat in the bin with just a simple on / off switch that I taped to one mirror and routed all cables on the back of the screen and down the spine for easy removal if required . I just undid the plug if I thought they may get tampered with and switched back on , although I have left them on whilst shopping ec..t with no issues .
I had some cheaper velcro ones to start with but one failed about after a year and was unable to replace but all Oxford bit's can be purchased easy and the same plug connector can be used with the charger ect..
Cheers Vk. .
Cheers Vk. .
- Jehova Empress
Hi Steve
I had the Oxford Scooter grips on the Jehovah.They were reasonably warm on the highest setting but I never tried the lower setting as the higher setting was only just adequate.
I have got a set of the British Army extreme weather mittens from ebay......they are fantastic,an inner pair that's thermal and an outer pair that's waterproof.......totally dry and warm,even with the heated grips turned off
Drawback of the mitts is operating switchgear etc but you get used to them
See ya soon
Spike
See ya soon
Spike
Got dr. bike heated grips on,never had any problems ,but these were on when I got it.
Oxford scooter grips are fitted to the Foresight I passed on to another member.
They consume 3 amps on low and 6 amps on high (72 watts), you really can't feel them on low, so you do need a 300w alternator to power them.
Worth a punt if you have a fully DC setup (and a kick starter) because they will flatten the battery.
How's that for real world experience.
Great thanks DD. On that basis I don't think I'll bother. A flat battery is something I don't want in a FI bike. Nothing to drive the pump so I would be stranded.
- Dr_StrangeTrick
- Rides:: C90
I have Oxford Hot hands also, the regular Oxford grips fit 22mm bars but our Hondas have 199mm so the Oxford velcro was the only choice
I have a 100w DC setup so I can't comment on how good they would be on a regular AC setup, but they do work pretty good
Only 'gripe' is when you have to take your hands off for a while they go cold and take a while go get hot again, that and you have to ride claw grip but that applies to any heated grip
I'm pretty sure the Wave is a full DC system.
- onittino3
Yep, I too don't notice them on low unless I'm wearing summer gloves, on high, ive found the faster you go the hotter they getDiesel Dave wrote:Oxford scooter grips are fitted to the Foresight I passed on to another member.
- Vk/Leeds
I thought that too for the innova ! ! but once I left my satnav connected for @ a fortnight in the garage covered over not even a neutral light when ignition turned on ! ! but it started first kick and all light ect.. resumed as normal with engine running ! ! but after a run I just disconnected the hot hands lead in the bin and plugged in the trickle charger over night to be on the safe side and never had any more issues with the battery , they consume less than 3 amps with a 2 year warranty and I shall be using mine again when the need arises .stevew wrote:Great thanks DD. On that basis I don't think I'll bother. A flat battery is something I don't want in a FI bike. Nothing to drive the pump so I would be stranded.
Cheers Vk. .
