My New Bike
- onittino3
Re: My New Bike
Dylan, would a switch like this fit on your handlebars...seem to cheap tho
Check out this item I found using the eBay Windows Phone App: http://ebay.us/o4O4bV
- Dylan
- Rides:: C90G 1987
Re: My New Bike
That's the one I have got Terry. I'm hoping it will fit. If it won't fit on the main handlebars then I think it could fit on my sat nav bracket with some adjustments.onittino3 wrote:Dylan, would a switch like this fit on your handlebars...seem to cheap tho
- onittino3
Re: My New Bike
Well great minds, you probably also have a wiring diagram for your bike but if not I found this PDFDylan wrote:That's the one I have got Terry. I'm hoping it will fit. If it won't fit on the main handlebars then I think it could fit on my sat nav bracket with some adjustments.onittino3 wrote:Dylan, would a switch like this fit on your handlebars...seem to cheap tho
http://www.apriliaforum.com/forums/atta ... 1383856583
Terry
Re: My New Bike
Interesting, shows you need a 'push to cancel' type winker switch....
- Dylan
- Rides:: C90G 1987
Re: My New Bike
So the switchgear above won't work. I'm guessing that's the same for the other one you posted Dave?Diesel Dave wrote:Interesting, shows you need a 'push to cancel' type winker switch....
I do have an Aprilia push to cancel indicator switch also but it will have to be a glue/gaffa tape fix!
- onittino3
Re: My New Bike
Oh...well that's a sh*t, not that hot on wiring, but from what I can see is it looks possible to wire the switch to turn the indicators on, using the slide switch but you would have to slide the switch back which wouldn't cancel the indicators , could you wire the Horn (momentary switch) to switch them off ????
Re: My New Bike
Whoa!
It depends on how the system works, if the 'on' function is momentary then we can use any other push button as a cancel function. If the 'logic' is in the switch rather than the flasher unit then that's all bolloxed.
There's nothing wrong with using a switched live, fitting your own flasher unit and wiring to that new switch, we just need to know the types of winkers (led or bulbs) and the wiring colours. From the looks of that diagram left is light blue and right is red???
- Dylan
- Rides:: C90G 1987
Re: My New Bike
I see it as the same as you Dave. Right - red & Left - sky blue.Diesel Dave wrote:Whoa!
- onittino3
Re: My New Bike
Yes I suppose it does mater were the logic is, its not the easiest wiring diagram to read, yea left light blue and right is red, it probably would be easier to run a switched live than decipher how the current system works.Diesel Dave wrote:Whoa!
- Dylan
- Rides:: C90G 1987
Re: My New Bike
I asked a question regarding the wiring and bulb type on the Mana forum and the response is below. Not sure if this helps Dave?
Stock indicators are bulbs. The Mana does not have a flasher unit as the indicators are controlled through the dashboard computer unit with individual wiring to all four. Front and back indicators are not connected together on each side. Colour of the wires sounds right, but the easiest way to do this is to piggy back the wiring to the original switch so the wiring to the actual indicators is irrelevant.
