It is in a very good state. It was blocked externally at around 5%. Cleaned most of the dead flies and the lot.davebike wrote:Look see if you can see though the rad finning externally blocked rads are a common problem either though careless cleaning or just plain road dirt !
It is definitely clogged up.
After leaving it with bleach in it, I can see what's wrong. Got a knife blade into one of the waterways and got out 3 things. The rubbery type brown stuff, a black rubber that was disintegrating and some sort of granules which are exactly like sugar granules (did not taste them).
Here is an attempt to capture the problem with my phone:
I have left the rad with rad flush overnight and will look at it this evening. Cleared the bleach with a lot of hot water... after the bleaching process, I could actually see the blockage. I had enough rad flush to fill the radiator without adding water. Hope it either cleans it, or ruins it since I need a good reason to buy a new one.
