Nah, 8000 so just ordered these for the 15000 main service (should give you time to extend your bike lift ) which will come up next year. Belt is specific for the Maxsym 400i and it's correct as it came from SYM with the right part number on it
SYM..Sanyang Motor Co they make Hyundai too, not a bad pedigree eh ?
If all goes to plan-----------
Re: If all goes to plan-----------
But you did dry lube the rollers and ramps on the variator and re-grease the clutch bearing with proper grease.
At 8K ????Diesel Dave wrote:But you did dry lube the rollers and ramps on the variator and re-grease the clutch bearing with proper grease.
